Page 358 of 845 FirstFirst ... 258308348353354355356357358359360361362363368408458 ... LastLast
Results 5,356 to 5,370 of 12672
  1. #5356
    Oct 2017
    alexm1, I've used version 17.8. Maybe I'm gonna try a newer version, but as long as everything works I'll stick to 17.8
  2. #5357
    17.8.1 en-ro: No adaptations, no bits on Long coding helper" The same as in 17.8.0 from august and 17.10 beta.
  3. #5358
    RF
    I wrote about this problem earlier.
    Quote Originally Posted by magadan View Post
    ....You will wait for the fact that substitution of public key, will become impossible, by means of a simple loader, it is necessary to do still something.
  4. The Following User Says Thank You to magadan For This Useful Post:
    liviudiaconu (19th December, 2017)
  5. #5359
    Feb 2017
    I can confirm that long coding is not working as expected in 17.8.1 (No correct items are shown for bytes). It's working in 17.1.3 and 17.8.0.
  6. The Following 2 Users Say Thank You to kolimer For This Useful Post:
    jakuza (3rd January, 2018), Tor999 (7th June, 2022)
  7. #5360
    Feb 2013
    About 17.1.3 - will work with v2 loader +dumps? Or you can help with new loader /dumps?
  8. #5361
    Oct 2014
    Netherlands
    I can confirm: 17.1.3 - will work with v2 loader +dumps.
  9. The Following User Says Thank You to H2Deetoo For This Useful Post:
    alexm1 (21st December, 2017)
  10. #5362
    Feb 2013
    Can you share download link for 17.1.3 software? Thanks
  11. #5363
    RF
    Quote Originally Posted by kolimer View Post
    I can confirm that long coding is not working as expected in 17.8.0 and 17.8.1 (No correct items are shown for bytes). It's working in 17.1.3.
    If created the correct public key, and then calculated the new digital signature for atmega EEPOM, then long coding will work.
    But there is also other way until it was forbidden by Ross.
  12. The Following 2 Users Say Thank You to magadan For This Useful Post:
    BWF (24th December, 2017), H2Deetoo (21st December, 2017)
  13. #5364
    Jul 2016
    Vilnius
    One question. Currently I have and use 17.1.0, I want to try out 17.1.3 and see if Long coding and UDS Adaptation work fine.
    Should I reflash the atmega with the dumps freshly or can I just reinstall the software to 17.1.3?
    Thank you
    * MK100
  14. #5365
    Dec 2014
    PL
    Quote Originally Posted by alexm1 View Post
    Hi. Here you have a link to VCDS 17.1.3 En. (Slow download)
    https://ulozto.net/!Jd4UHbfBjzIA/vcd...178.1513870186
    I fixed my broken VCDS 16.8.3En. Thanks to KOLIMER.
    I have three types of activators. One is Kolimers (V2) and 2 Chinese. And they all work correctly. I use VCDS 17.1.3 PL and everything works. I tried VCDS 17.8.0 PL (Kolimer activator) but I did not notice if everything works. (long coding).
  15. The Following 3 Users Say Thank You to Mario6 For This Useful Post:
    alexm1 (21st December, 2017), H2Deetoo (21st December, 2017), Rasmus55 (3rd May, 2019)
  16. #5366
    Jul 2016
    Vilnius
    Quote Originally Posted by Mario6 View Post
    In order to verify that the cable is fully working and safe, you need to try UDS adaptation channel, which is known to have a certain value.
    E.g. I test on Instruments cluster on 6 Golf, check Staging if it's Activve or Not Active. If you see some nonsense in such channel, means it doesn't work correctly and such interface is DANGEROUS.
    Meanwhile, Long Codings may work (or at least you won't notice that it works incorrectly, so relying only on that is not a guarantee
    * MK100
  17. #5367
    Dec 2014
    PL
    Probably you are right. I checked the cable only on VW Passat B6 2006 and B5 2004(runs slower on K lines). In my old VW I do not have UDS so I will not check it out.
  18. #5368
    May 2016
    Kaunas
    Quote Originally Posted by hid3 View Post
    Stagging is a bad example for checking the interface. Because only in some of the dashes these options are allowed. In order to activate Stagging it is necessary to adjust the EEPROM dump of the speedometer. There is no way to do this with vcds.
    My Passat B7 Speedometer did not have the ability to turn on Stagging with VCDS. I removed the speedometer, dumped the eeprom, corrected several bits, wrote back, and now I can activate or deactivate Stagging with VCDS
  19. #5369
    Jul 2016
    Vilnius
    Quote Originally Posted by vaicekas View Post
    Yeah, I know Staging is not available on all of them, but I gave it as an example of a thing, where you know expected values: Active / Not Active. if you see something else there, you know it's wrong. On your cluster, you can pick up *any* adaptation, which value you approx. know. It might be time till service, mileage since service, etc.. - it's your car and you know it.
    It looks like you really wanted to boast that you activated Staging on your car. On my car (Golf 6) it alsoo was not available, as it's only available on GTI/GTD/R versions. But instead of taking out the cluster, I had the EEPROM dumped via OBD port, amended the necessary bytes and pushed it back. In addition to that, I also enabled Volume To Be Replenished in menu and true coolant temperature indication
    * MK100
  20. #5370
    Jul 2016
    Vilnius
    So you mean that R0$$ made some amendments in versions later than 17.1.3 so that it stopped working correctly?
    Do we have a list of known-good working versions? Or should we make one? I can confirm that 17.1.0 and 17.1.3 are working absolutely correctly on 0x44 HW. Others feel free to add
    * MK100
  21. The Following User Says Thank You to hid3 For This Useful Post:
    tr3ce13 (23rd December, 2017)
