Page 363 of 847 FirstFirst ... 263313353358359360361362363364365366367368373413463 ... LastLast
Results 5,431 to 5,445 of 12691
  1. #5431
    Nov 2010
    17.1.3 works with kolimer's loader v1 v2 or v3?
  2. #5432
    Oct 2014
    Netherlands
    17.1.3 works OK with loader V2.
  3. The Following User Says Thank You to H2Deetoo For This Useful Post:
    tr3ce13 (4th January, 2018)
  4. #5433
    Feb 2017
    New loader V4 working with 17.8.1 available. Needed to rewrite avr eeprom. One multilingual eeprom is not possible anymore. Use VAGCOM_EEWriteLang to write eeprom of your choice.
    http://ge.tt/5RryFzn2
    https://www.sendspace.com/file/d9i4mo
    Kolimer
  5. The Following 34 Users Say Thank You to kolimer For This Useful Post:
    alexm1 (5th January, 2018), alin 151 (9th January, 2018), Andrey1842 (5th January, 2018), BWF (6th January, 2018), cawadany (6th January, 2018), cocutanu (7th January, 2018), dorcky (6th January, 2018), flavyus1987 (8th January, 2018), H2Deetoo (6th January, 2018), hartklep (6th January, 2018), hid3 (5th January, 2018), ivica21 (7th January, 2018), jakuza (6th January, 2018), jokir (6th January, 2018), jos68 (6th January, 2018), KayLastOS (8th January, 2018), kenzoo (6th January, 2018), kitnoos2002 (7th January, 2018), Majami (6th January, 2018), mamuko (7th January, 2018), Mario6 (6th January, 2018), matteosr (22nd January, 2018), mattock808 (6th January, 2018), mikroel (6th January, 2018), miouser (30th April, 2018), oleg68 (6th January, 2018), Papiti56 (14th January, 2018), relax80 (6th January, 2018), SDfgdhfj (6th January, 2018), SergeyIg (6th January, 2018), suntester (6th January, 2018), tr3ce13 (6th January, 2018), vaicekas (6th January, 2018), Warmopil (30th June, 2018)
  6. #5434
    Is it possible to use it in Spanish?
    I do not understand that a multilingual eeprom is not possible
    Thank you very much for the contribution of the V4 loader
  7. #5435
    Feb 2017
    Quote Originally Posted by BWF View Post
    Yes. Read next sentence : "Use VAGCOM_EEWriteLang to write eeprom of your choice"
  8. The Following 2 Users Say Thank You to kolimer For This Useful Post:
    BWF (6th January, 2018), kowalwalcz (6th January, 2018)
  9. #5436
    Internety
    Thanks Kolimer for your great job!
    If you have working e.g. 17.1.3 it is easy to update to 17.8.1
    [As VAGCOM_EEWriteLang.exe is detecting HW Type you can start from point 4]
    1. Check your HW type first with VAGCOM_HWType.exe to be sure about HW 0x44 or 0x46 (connect 12V to the cable)
    2. then extract HW you want form eepromavr_AllLang.zip (e.g. 0x46 AKP = PL) to seperate folder (e.g. eeprom_update)
    3. then to the same folder (eeprom_update) copy VAGCOM_EEWriteLang.exe
    4. then run VAGCOM_EEWriteLang.exe (in the same folder as eeproms), choose language you want (e.g. for AKP its polish), connect cable to USB and 12V and push WRITE, when done klick OK
    5. then install VCDS 17.8.1 in your language (e.g. AKP from vcds.pl) copy VCDSLoader.exe to main folder of VCDS and run it (loader)
    6. do the TEST of the cable (still connected to 12V) it will ask for update FW from 1.95 to 1.96. Do it. After update this is done.
    After another TEST you will see:
    ...and it is good time to connect to the car
    PS. I noticed it is better to use power supply like 12V 500mA, when I used 100mA I had issues with proper programming and TEST cable.
  10. #5437
    Trstenik - Thun
    Default VAG-COM/VCDS EVERYTHING
    Quote Originally Posted by kolimer View Post
    Kolimer
    Thank you for your hard work Kolimer.
    The problems with coding is solved with this ver.4?
  11. #5438
    Sep 2017
    Kolimer
    Chinese version 17.8.0,how do you crack the online verification?
    thanks for you work
    Attached file download address
    https://yadi.sk/d/YFSWG60-3REHkW
  12. #5439
    I tried this V4 and on my laptop with win7 x64 still is problem with correct finding rod file and with long coding, I tried to install VCDS as 32 bit and as 64bit version.
  13. #5440
    Oct 2014
    Netherlands
    @16D, what VCDS version did you try?
  14. #5441
    Jul 2016
    Vilnius
    Also, what car and which module were you trying where it caused problem?
    * MK100
  15. #5442
    Jan 2017
    For me, the v4 charger works well, I checked the long coding and it looks like it works well.
  16. #5443
    I tried vcds 17.8.1 Release in english, modules which I test on bench are 7N0907530AK and cluster 1K8920875D.
    Same interface but on win7 x32 works perfect with english version.
  17. #5444
    Sep 2016
    Hi, I have a question whether in the original version of the vcds interface, for example, Polish akp can be used with vcds in English.
  18. #5445
    Jul 2016
    Vilnius
    Yes, original VCDS interface can be used in 2 languages - the custom one and English.
    * MK100
