Page 364 of 854 FirstFirst ... 264314354359360361362363364365366367368369374414464 ... LastLast
Results 5,446 to 5,460 of 12803
  1. #5446
    Thanks Kolimer and everyone. I've updated to 17.8.1 and interface is working.
    I should always start VCDS with the loader or only the first time?
    LE: I'm trying to connect on bench to 18-Aux. Heat to recode one board but it doesn't connect. On the car CAN connection is working and I can access the module, but not on the bench. Can I do anything to make it work on bench?
  2. #5447
    Maybe you need corect pinout for your module.
    I tested on airbag kline and passat b6 with LC.
    All working for the moment.
    Thx kolimer!
  3. #5448
    May 2016
    Kaunas
    Quote Originally Posted by KayLastOS View Post
    You will not be able to run an aux. heater without a car. Only when connected in a car.
  4. #5449
    Quote Originally Posted by flavyus1987 View Post
    Thx kolimer!
    kline is working on bench. I will need a CAN gateway in the setup in order to work. I will try to get one from scrap yard.
    Quote Originally Posted by vaicekas View Post
    I am able to run it without the car with webasto software, but is not what I'm looking for. I want to code few things on the board which webasto software can't do.
  5. #5450
    Oct 2014
    Netherlands
    Make a specific module run on bench can be tricky.
    You need to make sure everything is in order for the module to work properly:
    - cabling (power, some other signals perhaps need to be present)
    - gateway can sometimes be needed (specially if your module uses a 100kbps canbus)
    - does the tool (VCDS) use the correct CANID? Sometimes it doesn't (like with UDS cluster) but gets corrected by gateway
    Rgs H2Deetoo
  6. The Following User Says Thank You to H2Deetoo For This Useful Post:
    KayLastOS (9th January, 2018)
  7. #5451
    Feb 2017
  8. The Following 37 Users Say Thank You to kolimer For This Useful Post:
    alexm1 (10th January, 2018), alin 151 (10th January, 2018), amaflo (10th January, 2018), Andrey1842 (10th January, 2018), bibkare (23rd January, 2018), big-ted (15th January, 2018), cawadany (10th January, 2018), darka7 (14th January, 2018), fantomel (10th January, 2018), Gyula84 (6th February, 2018), hid3 (10th January, 2018), I Vasil (9th February, 2018), ireun (20th January, 2018), ivica21 (11th January, 2018), jakuza (10th January, 2018), jokir (10th January, 2018), jos68 (10th January, 2018), kitnoos2002 (31st January, 2018), Majami (15th January, 2018), Mario6 (10th January, 2018), matteosr (22nd January, 2018), mikroel (10th January, 2018), miouser (30th April, 2018), networkers (10th January, 2018), ni88l3r (11th February, 2018), Novica (26th March, 2019), OMBRE (5th March, 2018), Papiti56 (14th January, 2018), rch11 (10th January, 2018), SDfgdhfj (10th January, 2018), tibby5 (22nd January, 2018), tr3ce13 (10th January, 2018), vaicekas (10th January, 2018), Vet (24th January, 2018), viking6791 (14th January, 2018), Wene001 (11th January, 2018), zecas (3rd February, 2018)
  9. #5452
    Oct 2017
    Germany
    Hello kolimer,
    Quote Originally Posted by kolimer View Post
    Announcing new loader V5.
    thanks for your work. i appreciate it very much!
    As far as i see, v4 is working well. I checked the german (DRV) version.
    What ist the difference between v4 and v5? I guess i need to reflash the Interface?
  10. The Following User Says Thank You to networkers For This Useful Post:
    Andeboy (19th February, 2020)
  11. #5453
    Oct 2014
    Netherlands
    Yes you need to reflash (only eeprom) the interface.
    Simply said, there is a bug which causes a memory leak when used with 17.8.x and up, which has been fixed in V5.
  12. The Following 6 Users Say Thank You to H2Deetoo For This Useful Post:
    alexm1 (10th January, 2018), ivica21 (11th January, 2018), mikroel (10th January, 2018), SDfgdhfj (10th January, 2018), spoon63 (10th January, 2018), tr3ce13 (10th January, 2018)
  13. #5454
    Oct 2017
    Germany
    Quote Originally Posted by H2Deetoo View Post
    Ok, great. Thanks for the quick response.
  14. #5455
    Jan 2018
    Hi. Will I be able to use the english version, when i flash polish eeprom?
  15. #5456
    What bugs we should check if it have been repaired?
  16. #5457
    I have to try v5 loader, my brother use V4 version in his Phaeton, today he wrote me that VCDS windows makas black when connecting with Comfort module of his car and VCDS uses 140MB in this moment, so I have to update interface to V5
  17. #5458
    Trstenik - Thun
    Work excellent on Golf4 1.9TDI 4WD
    Encoding ,adaptation , Power steering calibration, Haldex AWD checking ,CAN GAteway , Automatic scan ,Can,K-line ...
    good work Kolimer!
  18. #5459
    Oct 2014
    Netherlands
    If you want to use 17.8.x or higher then use V5 indeed.
  19. #5460
    Jan 2018
    Hey I just bought my VCDS cable, this one http://www.obd2tuning.com/vcds-kabel...at-p-2749.html but I install everything and need to register VCDS loader before I can use it. Is there a way I can generate registration or do I contact the Chinese seller. Also my version is "VCDS Loader V1.10.1 Setup(EN).exe" do I need to change to a newer version? If so will I need to register everytime. Sorry if this is common knowledge I am trying to read back through this very long thread to educate myself.
    John
