I have a Vag Com 11.11 clone atmega 162, is it possible to update to a newer version, and change language
is there a guide "how to do it"
Please help
Got a slightly different version: IMG_20180215_223000541.jpgIMG_20180215_223218682.jpg
It's activated for 17.8.0 english version.
How did you flashed to a different language?
Please help
atangx2 (20th February, 2018), Dynamicdk (20th February, 2018), liviudiaconu (20th February, 2018), Mario6 (20th February, 2018)
I manage to give some time to test v6.1 loader: is working fine with 18.2.0.
I saw that in v6.1 zip there is only VAGCOM_eewrite lang.exe (not VAGCOM_eewrite.exe as I found in v5), If I understood write: in this moment the last language chosen for writing atmega(via usb) will be the the only that will be with Registered License?
So, we can not use, two languaage's with the same cable as in previous vers? (ex. 14.10.0 )
No matter what will the answer to my questions...
God bless Kolimer (and all user's in the forum).
ATmega serial number is not blacklisted. Simply every new version of the loader under its own eepromavr and ftdi_id.
Newest loader 6.1 starts better on XP then v5 and also AV doesn't recognized it as potential threat, excellent work Kolimer, God bless YOU mate.
I found V6.1 (Thanks)
I need some help, how do I make 12V when programing my cabel, Do i put it into my car or do I use some pins on the cabel and make 12V power that way
I did read my cabel type, when the cable were connected to my car, and get this: vcds.png
Now I need to program it Progisp, but now I need help...
I did load the Projects, and the what to do..?
you have 12v on the yellow wire from the molex plug from the pc source
Any 12V DC Power supply will work.. just connect:
OBD2 PIN 16 to +12V
OBD2 PIN 4 to GND (minus)
I get at lot of " Unable to find a .ROD file for:"
will flashing a new fw help. og is it just a poor build off my "china cable" ?IMG_0073.JPG
Share some pics with the pcb.
What's inside it?
I'd take your case as a gift...
* MK100;
