Page 3 of 846 FirstFirst 123456781353103503 ... LastLast
Results 31 to 45 of 12688
  1. #31
    There are two screen shots. Can diagnostic does not work. But Block 1 (engine) has accepted code 11463. I tried to measure a resistance between pin 14 and pin 6 in diagnostic connector. It is impossible to measure. Resistance is too high.
    According to ELSA there is a can diagnostic in my T5
  2. #32
    Zagreb
    Quote Originally Posted by vstrglv View Post
    I have worked on t5 and sharan 2008 that shows can not ok , but program works with all moduls.
  3. #33
    Hello vstrglv,
    VAG-COM 607.3 is O.K.,Your HEX is O.K.Your T5 haven't CAN bus,01-Engine working using KWP-2089 protocol.
    with respect,
    igorm
  4. #34
    Quote Originally Posted by igorm View Post
    Hello vstrglv,
    with respect,
    igorm
    Hi, igorm, according to ELSA there is CAN bus and there is a two can bus pins in diagnostic connector. There is a note at can bus diagnostic connector pins - "Engine starts ". It means that an engine must operates for can diagnostic. But in my case there is no can diagnostic even an engine starts.
    Regards,
  5. #35
    DK Veteran rsibiza's Avatar
    Regards,
    CAN for this Car as for golf 4 has CAN between engine and cluster,and so it s not recognised as can for diagnostics
  6. #36
    One guy from http://www.vw-bus.ru/forum/ said that he had can diagnostic for T5, but in COM port, not USB.
  7. #37
    Hello vstrglv,
    In any case You haven't CAN bus.You don't need turn engine on to activate CAN,You just need to turn ignition ON.But in Your situation don't spend Your time about CAN bus,Your T5 can use KWP-2089 protocol and this is it...
    with respect,
    igorm
  8. #38
    Hello DORCKY,
    PLEASE CONTACT ME VIA PRIVATE E-MAIL.I HAVE SOMETHING WHAT CAN BE VERY VERY INTERESTED FOR YOU !
    with respect,
    igorm
  9. #39
    xoom's Avatar
    Ylakiai
    Hello DORCKY,
    with respect,
    igorm
    im interesested too can i contact too?
  10. #40
    Hello Xoom,
    I wish to have good news but for now NOTHING.I have something but friend tell me this is not O.K.,for now
    with respect,
    igorm
  11. #41
    xoom's Avatar
    Ylakiai
    PCB with Si9243..
    • Tested...
    • Working...
  12. The Following 10 Users Say Thank You to xoom For This Useful Post:
    deteli (23rd September, 2018), droid0101 (13th March, 2023), Fresk29 (17th February, 2018), haveje57 (27th January, 2022), KennySmit (3rd May, 2016), laki23 (10th March, 2023), ProblemChild (2nd May, 2021), Rebello Brian (12th August, 2020), semga (9th August, 2016), zZarZiLLoSs (25th May, 2020)
  13. #42
    ...here is difference between 9241 and 9243...
  14. The Following User Says Thank You to igorm For This Useful Post:
  15. #43
    Have anybody news about VCDS 10.6 ?
  16. #44
    hey guys, are all links down?
  17. #45
    where did the VAG threads all go?!
