Page 466 of 847 FirstFirst ... 366416456461462463464465466467468469470471476516566 ... LastLast
Results 6,976 to 6,990 of 12705
  1. #6976
    Feb 2013
    In this case, at some point (minutes, hours etc of use) Atmega will be fully filled up with info and will not be able to process the tasks we give?
    I did not notice this behaviour with 18.2....
  2. #6977
    Jul 2016
    Vilnius
    This behaviour has been there for ages I think.
    There are several bytes devoted for the counter.
    ATmega's EEPROM specified limit is approx 100'000 erase/write cycles before it gets exhausted. I believe this applies to every byte, not entire/total count.
    Assuming it's one byte only, then shouldn't be a problem, unless you are connecting/disconnecting the cable 1000s of times per day.
    * MK100
  3. #6978
    EU
    I'll try to explain. Tested multiple vcds versions 18.9 to 17.1.3 + different loader versions. 0x44 hardware. Even tested the same with flashed it to 0x46.
    When leaving Advanced measuring values opened for some time and checking some values (usually did first twelve for consistency), after X hours and Y minutes, vcds shows popup message with Communication error. This popup usually shows again 2 or 3 times after closing previous. Only option is to close it. After that opened ecu starts reconnecting (try 1, try 2, try 3) and then dies with No response from controller.
    X can be from 0 to 4 hours. Haven't tested longer. Y any number 0 to 59.
    Hid3 already knows all that.
  4. The Following User Says Thank You to kaalis For This Useful Post:
    liviudiaconu (15th October, 2018)
  5. #6979
    And after this, the cable is "broken" or still registered?
  6. #6980
    EU
    Licence is valid. Time is lost while logging those values and have to start again.
  7. The Following User Says Thank You to kaalis For This Useful Post:
  8. #6981
    Can be a counter but can be a RT programming error? I'll try how long i can on a 15 or/and 19.
    Anyway, IF cable=with AES after max 30 min is hot.
  9. #6982
    Jul 2016
    Vilnius
    Can you measure how much current is draining your cable with AES just connected to +12V and GND and left idle (VCDS not running)?
    Connect a multimeter in-line to measure that.
    Thanks.
    * MK100
  10. #6983
    Mar 2018
    Does Atmega EEPROM counter reset if reprogrammed?
  11. #6984
    Jul 2016
    Vilnius
    Yes, of course, but there is no way to restore the physical chip wear
    * MK100
  12. The Following User Says Thank You to hid3 For This Useful Post:
    muscles1960 (15th October, 2018)
  13. #6985
    Oct 2017
    Quote Originally Posted by hid3 View Post
    Problem is that 20 minutes is not enough... If possible, I'd suggest trying to keep it open for longer
    I've let it run over the night for 6 1/2 hours and the IC was 1 (initialization counter), TE=0 (transmission error) and RE also stayed at 0 (reading error)
    It was connected to a airbag module over a gateway module on my table
    I just opened it up, checked four values and let it run.
    I hope it helps
  14. #6986
    "airbag module over a gateway module"
    Can you tell me more about?
    How conected together?
  15. #6987
    Oct 2017
    I've bought a VW8 airbag module and a gateway module which was taken out off a VW golf 5 and touran and connected the modules to the corresponding can-lines. The airbag module pinout is:
    Pin 1 - +12V
    Pin 26 - GND
    Pin 49 - CAN-High orange black
    Pin 50 - CAN-Low orange brown
    Optional: Pin 31 - +12V
    and the complete pinout of my gateway:
    Pin 1 Klemme 30, Sicherung F24 in EM-Box rot blau
    x Pin 2 Klemme 30, Sicherung F24 in EM-Box rot blau
    Pin 3 nicht belegt
    x Pin 4 K-Leitung (nicht belegt)
    Pin 5 Komfort-Datenbus, CAN-Low orange braun
    Pin 6 Antrieb-Datenbus, CAN-Low
    Pin 7 nicht belegt
    Pin 8 Kombiinstrument-Datenbus, CAN-Low
    x Pin 9 Diagnose-CAN, CAN-Low
    Pin 10 Infotainment-Datenbus, CAN-Low
    x Pin 11 Klemme 31 (Batterie-Minus) braun
    x Pin 12 Klemme 31 (Batterie-Minus) braun
    Pin 13 Wake-Up-Leitung Kombiinstrument blau gelb
    x Pin 14 Klemme 15 schwarz gelb
    Pin 15 Komfort-Datenbus, CAN-High orange grün
    Pin 16 Antrieb-Datenbus, CAN-High orange schwarz
    Pin 17 nicht belegt
    Pin 18 Kombiinstrument-Datenbus, CAN-High
    x Pin 19 Diagnose-CAN, CAN-High
    Pin 20 Infotainment-Datenbus, CAN-High
    It's german, I don't have enough time to translate it to english, I'm sorry.
    I've connected the airbag module to pin 6 can-low and 16 can-high to the gateway and connected a OBD2-port bought out of ebay to pin 9 can-low and pin 19 can-high.
    Here you can see how the can-network looks in a VW Golf 5: h**p://www.christiani.de/pdf/82205_probe.pdf
    I've coded the gateway module to just look for the airbag module and it works just fine.
  16. The Following 4 Users Say Thank You to peetr For This Useful Post:
    hid3 (16th October, 2018), kaalis (23rd October, 2018), liviudiaconu (16th October, 2018), makadam (6th September, 2019)
  17. #6988
    Jul 2016
    Vilnius
    peetr,
    thanks a lot for your testing and the wiring diagram! These bits of information are really useful.
    Any chance you could repeat the very same test over upcomming night but just with English version of VCDS? (firmware/EEPROM of your cable doesn't need to be reflashed, it's compatible).
    Thank you!
    * MK100
  18. #6989
    Started one hour ago
    And after 2 hours..Unfortunately i must stop test..
    But still working.
    W10/64
    "46" HW
  19. The Following User Says Thank You to liviudiaconu For This Useful Post:
    belkor (16th October, 2018)
  20. #6990
    Oct 2017
    @hid3, this is how my setup looks like. It's pretty simple
    liviudiaconu has tested the english version of VCDS, but if you need more testing just let me know. I just need to find some time
