Page 474 of 854 FirstFirst ... 374424464469470471472473474475476477478479484524574 ... LastLast
Results 7,096 to 7,110 of 12803
  1. #7096
    Oct 2018
    16.8.3 cable after reflash works greate RT v18.9.0 Thank you!
  2. The Following User Says Thank You to DKa0S For This Useful Post:
    kaalis (29th October, 2018)
  3. #7097
    drewdom's Avatar
    Aug 2010
    58?59'13.1"N 6?11'19.4"E
    Hi friends.Can someone help me to identify this components:
    Please dear members push the button if my work was helpfull!
    And reputation button(star)
  4. The Following User Says Thank You to drewdom For This Useful Post:
    edmondcz (21st November, 2018)
  5. #7098
    Mar 2018
    Quote Originally Posted by drewdom View Post
    SS8050, (J3Y), Bipolar Transistor, NPN 25V 0.5A, SOT-23
  6. The Following 2 Users Say Thank You to Roma77 For This Useful Post:
    drewdom (29th October, 2018), kaalis (29th October, 2018)
  7. #7099
    xoom's Avatar
    Ylakiai
    sometimes there is 1AM transistors.. anyhow they are general purpose NPN transistors..
  8. The Following 2 Users Say Thank You to xoom For This Useful Post:
    drewdom (1st November, 2018), kaalis (29th October, 2018)
  9. #7100
    Apr 2016
    Default 18.9.0 - Ouput Tests not working
    I recently boufht a HEX-V2 (not real) with 18.2 s/w and f/w which included Kolimers Loader.
    It had the bootloader so I updated it 18.9.0 (one of the first versions by RT dated 27/09/2018 thanks to a member here).
    Did an autoscan on my new Polo 6C successfully.
    Managed to enable Needle Sweep/Staging in the 17-Instruments cluster
    Then I tried test the cable to some output tests on the convenience module.
    But non of the tests would work. But mostly I get an error usually "Refused by Control module".
    E.g. I tried to fold in the electric mirrors:
    So I can code but cannot perform Output tests.
    What could be the problem ?
  10. #7101
    May 2016
    Kaunas
    Quote Originally Posted by MacNB View Post
    if it's a MQB platform, then vcds will not handle it completely
  11. #7102
    Apr 2016
    Quote Originally Posted by vaicekas View Post
    I believe my 2017 Polo 6C is Mk5 based on PQ26 platform and not on the 2018 mk6 (based on MQB A0 platform).
  12. #7103
    Mar 2018
    I've got a Polo 6c 2017 GTI. I'll check mine on Wednesday when I have time and report back. Done various adaptations and long coding but not tried live data output.
  13. #7104
    Oct 2018
    Default VCDS 18.2.1 English activation
    Can someone send me the activation file for my vcds loader 1.12 vcds 18.2.1 English, please?
    request_license_dd0804e7.rar
  14. The Following User Says Thank You to Aramos95 For This Useful Post:
    seal777 (5th November, 2018)
  15. #7105
    Apr 2016
    Quote Originally Posted by muscles1960 View Post
    Cool. thx.
  16. #7106
    Oct 2018
    Quote Originally Posted by hid3 View Post
    Yes, VCDS software can brick your interface. It's what it was designed to do
    It writes in EEPROM A1, A2, A3,.... An B1, ... Bn, etc to certain section instead of actual data.
    Please post PCB of your Fake-V2
    Do you mean the following info: HW version: 0x46 / FW version: 1.96
    I read that info out from the interface, or do I need to open the interface to get the needed information?
  17. #7107
    EU
    Yes, better open it to see atmega and other parts.
  18. #7108
    fantomel's Avatar
    Mar 2009
    Us
    If you like my post and it helped you please press THANKS.
  19. The Following 16 Users Say Thank You to fantomel For This Useful Post:
    alin 151 (30th October, 2018), AYD (31st October, 2018), cawadany (16th November, 2018), ionutdanica (9th November, 2018), jakuza (1st November, 2018), jan4 (30th October, 2018), kaalis (30th October, 2018), kowalwalcz (30th October, 2018), kurekpit (31st October, 2018), Mario6 (30th October, 2018), Mrjitter (12th November, 2018), peetr (30th October, 2018), poilodo (30th November, 2018), rak183 (30th October, 2018), seal777 (5th November, 2018), vm44 (30th October, 2018)
  20. #7109
    May 2014
    please delete.
  21. The Following User Says Thank You to dj2d For This Useful Post:
    Aramos95 (30th October, 2018)
  22. #7110
    Oct 2018
    Hello everyone, I have a 18.2 cable and when doing long coding changes my coding is accepted but not saved. What can I do to fix this?
    Also is my cable able to be reflashed to the 18.9 ? Hope you can help me.
    Here is the PCB
    https://imgur.com/a/MKK3r4K
