Thank you all for your suggestions. That sounds like a lot of trouble for just one cable.
I guess I'll just stick to the BL cable :P
Attn: If you chose to make yourself a GAL programmer, when make tests for programming GAL/ATF, buy few chips for test, they are very sensitive and can damage very easy. After your tests are succesfuly for few chips, you can programm your GAL.
I tred make myself 2 or 3 programmers for GAL but..none with good results, so, i bought Genius 540.
I don't tell you "don't make". If you want, can make programmer, but i told you what is possible to happen...
Carlos mate no offence but where that words:
"But in my case, this is an hobby for me, not a business. So I'd rather make an homemade cable to save money and to practice my soldering skills"
Where's the adventure, where is the pleasure to make something with your hands?
Or I don't get it well the simnification of word HOBBY?
When you talking about HOBBY there's no "too much", there's no effort" there's "no benefit" There's just Hobby, passion and proud that you do something by yourself. Noone need to kiss your ass, there's just proud for yourself
Good luck
P.S> take my frined liviu advise becasue a pro solution it is allways better then a home made one when a Genius G540 not cost a lot on ebay and it is doing it's job very well
I have got a small problem with VCDS beta 912. I had problem with this device - It has been recognised as USB<->serial. I have done some changes in driver (to have PID and VID exact same as in my recognised device). After that I started VCDS. It told me, my cable is crashed, so it can repair. I clicked on "OK". After repair, cable is visible for VCDS, but I have message "Interface status -2", when I try to connect. When I go to "about" in VCDS, I can see "unregistered/unauthorized". I am trying to flash it with mprog with dump from this thread:
http://www.digital-kaos.co.uk/forums...3/#post1321492
But still "Unauthorized". Can you tell me how can I fix this interface ? Can I write any newer dump than 912 ?
Thank you. Where can I find proper dump ?
Unfortunately I have RL type. Can you show me which elements do I have to remove for flashing ?
Yes, I can see. Thank you. Is it possible to remove ATMEGA and GAL and program them in external programmer ?
upsssssss
I can help you but only if you want me to help you
All the questions should start from what car, what year, what engine is what fuel. What are the symptoms of the problem. Only then is what you know, what fault code, live data, what you have done.
