Page 396 of 847 FirstFirst ... 296346386391392393394395396397398399400401406446496 ... LastLast
Results 5,926 to 5,940 of 12705
  1. #5926
    EU
    Solder small wires to atmega162 pin #1, #2, #3 and #4 or follow PCB for easier location. Connect them to appropriate pins on usbasp. Put +12v and ground to obd2 connector. Connect vcds cable to USB. Flash with Kolimer's ...eewritelang. And update firmware through vcdsloader port test. BTDT today.
    Before that tried without soldering but didn't work.
  2. #5927
    Feb 2018
    Hello Friends.
    Can anybody help me clone FT232RL chip all eeprom,And Please say If this is possible?
    Read EEPROM successful Device 0
    0000 : 08 40 03 04 24 FA 00 06 80 19 08 00 00 02 98 14 @. .. .. .. .. .. .. ..
    0010 : AC 24 D0 12 23 10 05 00 14 03 52 00 6F 00 73 00 .. .. .. .. .. .R .o .s
    0020 : 73 00 2D 00 54 00 65 00 63 00 68 00 24 03 52 00 .s .. .T .e .c .h .. .R
    0030 : 6F 00 73 00 73 00 2D 00 54 00 65 00 63 00 68 00 .o .s .s .. .T .e .c .h
    0040 : 20 00 48 00 45 00 58 00 2D 00 55 00 53 00 42 00 .. .H .E .X .. .U .S .B
    0050 : 12 03 52 00 54 00 30 00 30 00 30 00 30 00 30 00 .. .R .T .0 .0 .0 .0 .0
    0060 : 31 00 02 03 01 00 00 00 01 5F 9D A1 9B 40 FD F0 .1 .. .. .. _. .. @. ..
    0070 : 72 40 B2 EC 56 6B 00 00 00 00 00 00 00 00 07 7F @r .. kV .. .. .. .. ..
    0080 : 3F 04 C0 FB 00 00 E1 D3 E3 48 42 00 00 00 00 00 .? .. .. .. H. .B .. ..
    0090 : 00 00 00 00 00 00 00 00 4B 41 30 5A 44 33 35 38 .. .. .. .. AK Z0 3D 85
    This need clone to new FT232RL chip
    (0080 : 3F 04 C0 FB 00 00 E1 D3 E3 48 42 00 00 00 00 00 .? .. .. .. H. .B .. ..)
    (0090 : 00 00 00 00 00 00 00 00 4B 41 30 5A 44 33 35 38 .. .. .. .. AK Z0 3D 85)
  3. #5928
    Feb 2018
    THIS is a 12.12 any idea of chipset as Its my friends. Will it flash? . Anyway works on 12.12 even can so is usable at the moment.
  4. #5929
    Feb 2013
    This one has Nec cip inside, no change to reflash. Find a good cable with Atmega...
  5. #5930
    Jan 2017
    Quote Originally Posted by sunis View Post
    Hello Friends.
    FT Chip ID can't be cloned.
  6. The Following User Says Thank You to engycz For This Useful Post:
    jakuza (27th March, 2018)
  7. #5931
    Feb 2018
    Quote Originally Posted by alexm1 View Post
    I thought as much. It works fine with 12.12.....just keep it offline. My 17.1 is faulty so going to order another.
    Thanks for the reply.
  8. #5932
    Mar 2018
    sweden
    Quote Originally Posted by r0bertt View Post
    Has someone use AVR Studio for program vcds and could give some tips/screenshots?
    I did dump my 16.8 Atmega162 memory and EEPROM using Atmel ICE and Atmel Studio.
  9. #5933
    Mar 2018
    sweden
    Quote Originally Posted by networkers View Post
    Two versions of 17.8.1 en https://mega.nz/#F!or5AQTwY!GxLeQwZkfOaogV0HCERViA
    One (V1) is working with v5 loader, second (V2) should work with v6.x loader
    Where can i get the loaders ?
  10. #5934
    Feb 2013
    Read a few pages back (10 or more) and look for Kolimer's post, he posted a link.
  11. #5935
    May 2017
    Hi!
    I read few pages of this thread but i don't understand a lot of things
    I have this interface. I want to program it. I have .hex to it.
    Atmega162, FT232RL, china clone , vcds 17.1.3 (if it's possible i want to upgrade it to 17.8.1)
    Which HW version do i have? 0x44 or 0x46. I tried to use Kolimer's VAGCOM_HWType but i got "No response". i installed drivers and interface is present in device manager as "RossTech Interface".
    I want to buy programmer. Is this (see image below) good? I see 6 pin on my cable and this programmer has 12 pins. Will it fit?
    Sorry for english
  12. #5936
    Feb 2013
    Your cable is 0x46 and search in google for "usbasp pinout" ...you will find that answer on this topic too...
    By the way, from those 6 pins header on the cable you will use only 4..Miso Mosi Sck and Reset. Buy that usbasp and read more in this topic you will find everything you need...
  13. #5937
    xoom's Avatar
    Ylakiai
    GND is also necessary..
    also for VAGCOM_HWType something is not right with VID/PID.. try first rewrite FT232 with files supplied with loader..
  14. #5938
    Does the loader 6.3 work with the VCDS V2?
  15. #5939
    Junior Member Adyp's Avatar
    Mar 2017
    I have a Hex v2 (i know, old stuff with new coat) and with v6.3 loader I receive this message when autoscan:
  16. #5940
    EU
    Quote Originally Posted by rivit View Post
    You should recount them and read more pages. Also couple pages from beginning.
