* MK100;
Are you having some problems with it? Have you plugged the interface into OBD2 before you try hwread?
* MK100;
eliteland786 (14th May, 2018)
RT is securing it's territory. But originals are not much better in this platform.
About hardware in the pics below.
Reading with vagcom_hwtype I get x46 type and offcourse Atmega pin 34/35 is conected to pin 5/4 of ATF and that mean is x44?
So I should use x44 flash and eeprom from Kolimer's zip?
Have you actually checked/confirmed that with multimeter, that both pins are connected?
* MK100;
Yes, I did use a multimeter.
There are two small holes, traces from Atmega pin 34/35 on a side and goes to other side to pin 5/4 on ATF, no doubt about that.
Well, then it definitely seems this piece of hardware is 0x44.
Would be ncie if experts could chime in and comment...
* MK100;
It's not clear what they exactly do.
But L-line (if equipped on a car) does not work in any configuration rather than both jumpers removed.
If someone knows what those jumpers do, please post.
* MK100;
What I know is that exactly this interface was indentified as a x46 many many pages ago, and it's even mentioned in the pdf as a x46 interface. It's the same pcb layout, except that the pins are connected. Someone said that this is the recommended high quality interface (and his pins were connected too).
I have exactly this interface too and mine works with the x46 firmware just fine.. In fact, it should be a x44 interface because of the two connected pins (at least visibly, I didn't checked it on my cable) but the x46 firmware works.
I don't get it.
