I have vcds 12.1 clone , but using genuine serial number
what version of vcds is ok to use with it .?
using outdated version 8.something .
need newer version for 2008 + audi
Hy,
I am trying to fix a vcds with FTDIRL, so when I opened I saw traces of solder wire on MCP2515 and ATmega162, although GAL is in his place, and the other 3 parts: R51 .. etc;
It may have been possible to be repaired without removing the GAL??? Because are no signs of soldering traces on Gal.
I already tryed to reflash Atmega and FTDIRL ( without removing parts) , first time I used 11.2 dump and second time with 11.11 dump.
Results: NO LUCK
-for 11.11 dump - when I conect the cable to the car I got this error : Status: Selft test failed! If I test the cable not conected to car no error;
-for 11.2 error :Interface status= -2...Firmaware update needed.
Hi, i buy chines clone VCDS 11.11.2 czech language, russian language to test... write in diagnosing it writes too many errors to communicate ... how to fix ??
Do not forget to THANKS !
SWIFTECH FULL
ECM Titanium FULL
KESS V3
AUTOTUNERS
B-FLASH
WINOLS
TOPDONE
AUTEL
FILE SERVISE .. web under construction
no way.
this crap is without atmega and gal/pal
but it has all the things except GAL ans security chip
maybe it will work? Who knows...
No Signature
Yes there Nec, not atmega. Any idea to fix?
SWIFTECH FULL
ECM Titanium FULL
KESS V3
AUTOTUNERS
B-FLASH
WINOLS
TOPDONE
AUTEL
SWIFTECH FULL
ECM Titanium FULL
KESS V3
AUTOTUNERS
B-FLASH
WINOLS
TOPDONE
AUTEL
hello
I have a problem with my vcds (clone).
Worked great but at some point it does not work.
Flashing red light?
atmega is programmed ok!
93C46 is ok
I make some test programs VCDS - it behaves as if there was no communication with the car.
help?
So, when flashing red led?
When power on?
Light red and after green or red an red-flash?
If red-redflash see the solders, maybe an imperfect-contact on CI
Here is a video by connecting the power
