Hi, I'm looking for working VCDS LITE for old KKL interface.
Thank you.
Thank you.
search vcds lite on FileCrop - Search and Download Rapidshare Megaupload and Hotfile Files
__________________
China: OPEL Tech2 non-CAN multiplexer USB, OP-COM USB, OBDII Elm327 USB, VAG-COM 409.1/VCDS Lite 1.0 KKL USB
Homemade: UNISCAN Visa 1.83 RS-232, Renault XR25PC USB, BMW KKL USB, Nissan Consult1 USB
Is ok now, i reflashed the VCDS RL, like in tutorial of Aminebot. Is work ok on K/L... I don't know how work on CAN...
Please help,
My China made VCDS 10.6.2 cable has stopped working, and cable is not recognized by VCDS. How to recover from this iiseu?
My cable is recognized, and with vidpidfix I am doing as described in many instructions, but after pressing Open, vidpidfix crashes when in status windows -reset- appears.
I also have a similar problem when I run vidpid error occurs
Hi, friend of mine brought me 2 VCDS 805 BL for reflashing, but there is something wrong with them? Both cables when I plug them into +12v the led light goes red and blinking, is not green. I reflashed Atmega with few different dumps and still led light is red and blinking, and interface not found during the test. Beside this on one of the cables stabilizer 7805 goes very hot after while. Any sugestions???
Ok, thanks, I'll try to change Atmega and will see what will hapened. Thanks.
Excuse me for my english but i've a usb willem programmer,it's possible to flash a atmega162??
Maybe i've need a adaptator?
thks
Hi, can somebody help me with GAL programming?! I tried program GAL16V8B on 3 different programmers but still without the success![]()
It doesn't matter if I program brand new GAL or from the cable, the content of the GAL after programming is diffrent than the used .jed file-and I don't know why??? I erased the Gal before programming then load .jed file the whole programming proces goes true, no error messages, and after that when I read the Gal the content programmed Gal is different than the used .jed file.
Please tell me what I'm doing wrong?
