laserkill (3rd May, 2018)
* MK100;
Here it is i want software its not china product you can se also pcb
Sent from my SM-A310F using Tapatalk
These tool is to read dashboard key pin and also change km in older models 1998 2004 vw Audi skoda.
* MK100;
rak183 (3rd May, 2018)
Ok guys, so I reprogrammed my cable HW:1.92 0x46 using loader 6.3. When I test the key with 17.8 with no 12V applied I get thumbs up. But when I connect 12V to it I get a message that Interface is not found and VCDS software comes up with unregistered message. What am i doing wrong?
Pics of the PCB..?
* MK100;
Here it is.
Gal16v8 dead, replace and reprogram or bypass the gal.
Keep in mind, English is not my native language.
This is the other side. How do I bypass the GAL? I was under impression I don't have one on my board.
Ok sorry, now I see the GAL location. Where do I find info on bypass?
it's here in DK archive use GoogleOk sorry, now I see the GAL location. Where do I find info on bypass?
I found the info on how to remove the GAL and solder the additional 3 wires. Will do this over the weekend. Anyways, I understand that i will loose K-Line support. My question is what exactly K-Line is used for? I need to disable my handbrake on our Tiguan so I can change the rear pads and I need to reset service interval on our Audi Q5. Will I be able to do that without of K-Line support? Thanks.
Removing Gal solution...is not a solution, was released a few years ago for experimental entertaining I think, just to give a second chance to a cable...But does it worth waste time and at the end you will have a non-fully functional cl0ne ?
