Thank you, fixed.
VCDS_17.1.3_v2.zip https://mega.nz/#!oyowxRDY!1vVTUiAJD...ABkmS-Qtlrjupo
Thank you, fixed.
1 6 D (22nd March, 2017), alexm1 (21st March, 2017), alin 151 (27th May, 2017), Andrey1842 (27th March, 2017), bibkare (8th June, 2017), cinek2006 (18th April, 2017), Col19 (23rd January, 2019), hartklep (12th April, 2017), hp7909 (28th March, 2017), JetSet59 (28th March, 2017), jos68 (23rd March, 2017), oleg68 (22nd March, 2017), RogerioAndrade (21st March, 2017), Sparky1521 (28th March, 2017), tehnosoftex (23rd April, 2017), tr3ce13 (4th June, 2017), vaicekas (25th May, 2017), vvucic (22nd March, 2017)
See the picture http://www.obd2cartool.com/vagcom-16...version-p-1266
facom01 (25th March, 2017), ghicicine (1st December, 2017), ovidiumarin (5th May, 2018)
Yes . Photos look like mine. No designation of the connectors
http://www.digital-kaos.co.uk/forums....php?p=2986116
Gesendet mit Tapatalk
Great job Kolimer!
Specially the included "hwtype tool". It made possible I realize my Chinese tool (that without GAL) is "0x44" and use correct dumps!
Your "VCDS 17.1.3 crack" opens almost all function. Actually, all that I wanted (Folding mirrors, etc).
Now, I've successfully tested versions 11.11.3, 12.12/11.11.5 and 17.1.3 posted before, here and in this thread: http://www.digital-kaos.co.uk/forums/showthread.php/237263-VAG-COM-VCDS-LATEST-DUMPS
Special thanks to mattydr67, fantomel, alexm1 and kolimer
Greetings,
Rogerio
facom01 (25th March, 2017), ovidiumarin (5th May, 2018)
Hmm .I know for what that is the header .
Find nothing about OBD2Cartool VCDS with programming header and Connection to usbasp
Accurate allocation
Header pinout
FoxMulder (22nd March, 2017), ovidiumarin (5th May, 2018), RogerioAndrade (22nd March, 2017)
Maybe this will help you all to connect VCDS to a programmer.
If you like my post and it helped you please press THANKS.
apsol (6th September, 2019), apv (23rd March, 2017), assist9 (5th December, 2017), Col19 (23rd January, 2019), darka7 (23rd March, 2017), FoxMulder (22nd March, 2017), Gyula84 (28th October, 2018), H2Deetoo (7th November, 2017), kaalis (25th February, 2019), lokipepe (22nd March, 2017), Newsolds (12th May, 2023), ovidiumarin (5th May, 2018), RogerioAndrade (22nd March, 2017), seal777 (7th July, 2019), Tor999 (6th June, 2022), vvucic (29th March, 2017)
Great work, Autoscan is going better, but long coding still doesn't work. In previous crack and this there is problem with searching ASAM data for UDS modules, it changes names, there should be "EV_Kombi_UDS_VDD_RM09_A04..." but it searches every time other like: "EV_KombiU_DS_VDD_RM09_A04","EV_Kobmi_UDS_VDD_RM09 " or "EV_Kombi_UDSV_DD_RM09_A04" or other with mistakes.
Hey all I'm trying to use kolimer 17.1.3 software with my fly508.
Has HW0x46
Anyway I can do this? If so I would need help locating FTDI and ATMEL
Hass42
I think your tool is for:
Honda HDS、Ford and Mazda IDS、Landrover JLR IDS、Toyota TIS.
Kolimer software is for vcds=VAG GROUP.
mikroel (31st March, 2017)
Mate do not make confusion between VAG Group and VCDS tool
Fly is a diffrent tool then VCDS
Your tool will not work and you cannot make it works with VCDS Ross-Tech softwares ever.
This is what alexm1 wanted to tell you
Good luck
alexm1 (24th March, 2017)
This is a VAG Commander I suppose
Also you cannot make it works
Mate take a look in this thread and you will can see many pics of VCDS
Most of item bad one but others good one
Good luck
P.S.
VCDS must have:
Atmega162
GAL/ATF16V8
MCP2515
TJA1050 (MCP2551)
L9637D ( tranzistors in other cases )
FTDI BL or RL
