Page 395 of 846 FirstFirst ... 295345385390391392393394395396397398399400405445495 ... LastLast
Results 5,911 to 5,925 of 12679
  1. #5911
    Apr 2012
    I didn't short circuit anything and didn't reflash ft232 . There was no mention about that in info.pdf. Is there any guides for that?
  2. #5912
    Oct 2017
    Germany
    According to Info.pdf:
    Hardware with STC chip
    Before programing cut line from pin 9 of STC. No need to do more then that or remove it.
  3. #5913
    Apr 2012
    I have cutted line pin 9 as I said.
  4. #5914
    Oct 2017
    Germany
    What happens if you try to reflash the interface with "VAGCOM_EEWrite.exe"?
  5. #5915
    May 2014
    Quote Originally Posted by tucano79 View Post
    I tryed V6 with 18.2 on MQB chassis... On golf 7 works. It doesn't works on audi A4 B9 and Q5 FY. Have anyone notice about new car MQB ? Which model does 18.2 V6 works or not works?
    As far as I know only the real V2 RT interfaces are compatible with new MQB platform...
  6. #5916
    Apr 2012
    Finally got it working! First flashed atmega162 + eeprom and then ftdi with vagcom_eewritelang. Now self test passed but can is still not ok. Any ideas?
  7. #5917
    Feb 2018
    Hi everyone, i'm new on this forum and i wanted to update my VAG HEX+CAN 17.8 ENG clone to 18.2 ENG /17.8 ITA. According to "VAGCOM HW Type" i have a FW version 1.96, HW version 0x46 and identification Ross-USA. Is it possible to update it directly via "VAGCOM_EEWrite.exe" ? Or i need to use USBASP?
    Thanks.
  8. #5918
    Feb 2013
    Quote Originally Posted by toglader View Post
    Tested on the car? What year model...etc.
    Quote Originally Posted by thunderbolt96 View Post
    Thanks.
    Try and see if it is working or not, ....because it depends from were you have it and what is inside of Atmega...
  9. The Following User Says Thank You to alexm1 For This Useful Post:
    openit (20th March, 2018)
  10. #5919
    Feb 2018
    Quote Originally Posted by alexm1 View Post
    I can use the molex from my pc or canbus connection in car with ignition ON to give power at the vag cable while flashing it? I don't have an external power supply unluckily.. I bought it on aliexpress, it has a ATMEGA162 + 16V8 + FT232RQ chip inside. If the flash via usb fails i have to do it again using USBASP? Sorry for the questions but i'm a newbie and i'm trying to learn.
  11. #5920
    Feb 2013
    You can power up via obd2, if will not work to flash by usb...dump inside Atmega will be the same and if it is working now will still work after that. Reflash Ft232RL only after reflashing Atmega.
  12. The Following User Says Thank You to alexm1 For This Useful Post:
    thunderbolt96 (21st March, 2018)
  13. #5921
    Feb 2018
    Hey guys, what an amazing thread!
    I want to buy a better cable to mod and use with the loader.
    But I'm a little lost...
    Which one do I need to buy from Aliexpress/ebay to mod and use with the loader?
    Thanks!!
  14. #5922
    Feb 2018
    Tried today to update using "VAGCOM EEWRITELANG" and i got the error "not in bootloader mode". So I assume that i have to flash it manually using USBASP with Progsip and MProg, right?
  15. #5923
    Oct 2017
    Germany
    Yes 100% correct.
    You can also use avrdude to flash atmega162. http://savannah.nongnu.org/projects/avrdude/
    Batch/CMD files are in loader zip file.
  16. The Following User Says Thank You to networkers For This Useful Post:
  17. #5924
    Jan 2018
    Quote Originally Posted by dj2d View Post
    Thank you. I tried V6 and in some MQB model it works good but in other not good.
  18. #5925
    Junior Member Adyp's Avatar
    Mar 2017
    Quote Originally Posted by Adyp View Post
    Hello all!
    I have read almost all 300 pages on this thread, very useful, thank you all for sharing info.
    Almost a week ago I have bought a clone, seller delivered a CD with official 17.1.2, on description said that official software will work. At least that i could read on that CD, it was a bit damaged. After autoscan license gone, Unregistered appeared. No internet, no update, just software from CD. I have contacted seller, no answer until now.
    Meanwhile, I have found some software, recovery.exe, and worked but when I am scanning I get some communication errors.
    Can I make it to work as it should?
    Pictures attached with inside!
    Attachment 441114Attachment 441115
    Sorry for my late post...
    Attachment 441635
    I know that I had very few chances to do something about this but maybe now there is a solution... or going to trash?
