Page 379 of 847 FirstFirst ... 279329369374375376377378379380381382383384389429479 ... LastLast
Results 5,671 to 5,685 of 12704
  1. #5671
    Feb 2018
    Quote Originally Posted by smerfus79 View Post
    Got a slightly different version: IMG_20180215_223000541.jpgIMG_20180215_223218682.jpg
    It's activated for 17.8.0 english version.
    How did you flashed to a different language?
  2. #5672
    Jul 2010
    I have a Vag Com 11.11 clone atmega 162, is it possible to update to a newer version, and change language
    is there a guide "how to do it"
    Please help
  3. #5673
    xoom's Avatar
    Dec 2009
    Ylakiai
    Quote Originally Posted by Dynamicdk View Post
    Please help
    How many pages do you read back ? I think in 5 pages you will find everything..
  4. The Following 4 Users Say Thank You to xoom For This Useful Post:
    atangx2 (20th February, 2018), Dynamicdk (20th February, 2018), liviudiaconu (20th February, 2018), Mario6 (20th February, 2018)
  5. #5674
    Feb 2013
    I manage to give some time to test v6.1 loader: is working fine with 18.2.0.
    I saw that in v6.1 zip there is only VAGCOM_eewrite lang.exe (not VAGCOM_eewrite.exe as I found in v5), If I understood write: in this moment the last language chosen for writing atmega(via usb) will be the the only that will be with Registered License?
    So, we can not use, two languaage's with the same cable as in previous vers? (ex. 14.10.0 )
    No matter what will the answer to my questions...
    God bless Kolimer (and all user's in the forum).
  6. #5675
    Jul 2017
    Quote Originally Posted by ccr64k View Post
    Unpacked exe
    Can somebody find where is blacklisted Kolimer v5 serial and where the blacklisted serials are checked?
    It's great that you succeeded to unpack and decode the original.exe file.
    But unfortunately there is such error:
    None of the Kolimer (v1 ... v6) serial numbers are blacklisted up to version 18.2.0
  7. #5676
    Oct 2016
    Quote Originally Posted by BASi77 View Post
    Kolimer v5 FTDI_ID is blacklisted in version 18.1.0-18.2.0
  8. #5677
    Jul 2017
    Quote Originally Posted by 34260551 View Post
    ATmega serial number is not blacklisted. Simply every new version of the loader under its own eepromavr and ftdi_id.
  9. #5678
    DK Veteran bibkare's Avatar
    Feb 2010
    B & H
    Newest loader 6.1 starts better on XP then v5 and also AV doesn't recognized it as potential threat, excellent work Kolimer, God bless YOU mate.
  10. #5679
    xoom's Avatar
    Dec 2009
    Ylakiai
    Quote Originally Posted by bibkare View Post
    Yep, that was fixed in V6.1
  11. #5680
    Jul 2010
    Please help
    I found V6.1 (Thanks)
    I need some help, how do I make 12V when programing my cabel, Do i put it into my car or do I use some pins on the cabel and make 12V power that way
    I did read my cabel type, when the cable were connected to my car, and get this: vcds.png
    Now I need to program it Progisp, but now I need help...
    I did load the Projects, and the what to do..?
  12. #5681
    Nov 2015
    romania
    you have 12v on the yellow wire from the molex plug from the pc source
  13. The Following User Says Thank You to gini80 For This Useful Post:
  14. #5682
    xoom's Avatar
    Dec 2009
    Ylakiai
    Any 12V DC Power supply will work.. just connect:
    OBD2 PIN 16 to +12V
    OBD2 PIN 4 to GND (minus)
  15. The Following User Says Thank You to xoom For This Useful Post:
  16. #5683
    Feb 2018
    Quote Originally Posted by xoom View Post
    OBD2 PIN 16 to +12V
    I get at lot of " Unable to find a .ROD file for:"
    will flashing a new fw help. og is it just a poor build off my "china cable" ?IMG_0073.JPG
  17. #5684
    Feb 2013
    Share some pics with the pcb.
  18. #5685
    Jul 2016
    Vilnius
    What's inside it?
    I'd take your case as a gift...
    I can calculate ABS module codings for:
    * Continental/Teves MK60EC1 and MK60;
    * TRW systems in Passat B6 / B7 / CC /Tiguan;
    * MK100
    * Bosch ABS8.2, ABS9.0 and ESP8.2, ESP9.0;
    * EBC 460 (UP!, Mii, Rapid, CitiGo, Fabia, Toledo, etc) New!
    ... and other VW/Audi/Seat/Skoda modules.I can assist with repairing \/CDS interfaces.
