@Majami, using 17.8.0 EN can you check an UDS cluster and go to Adaptation channels and choose "staging" channel and see what is read?
Several people get a "km" result and not "active" as it normally should be.
The STC will reflash the ATMega it seems, so you need to remove it if you plan to upgrade yourself. Otherwise the STC will reflash back to some old version.
You can simply remove 1 resistor (R50) but you can also simply remove all (STC+RESISTOR+TRANSISTOR).
I can confirm that Beta 17.10.0 has some problems with CAN communication.
autodiagdoctor (16th November, 2017), H2Deetoo (16th November, 2017), ivica21 (25th November, 2017), jakuza (21st November, 2017), liviudiaconu (16th November, 2017), Majami (16th November, 2017), radsky (20th November, 2017), relax80 (19th November, 2017), tr3ce13 (16th November, 2017)
Also 17.8.0 gives problems for several different users at least (UDS cluster adaptation f.e.)
Hi, friends
we have new ATMEGA162 HEX-V2, HEX V2 VCDS 17.8 full active cable For VW Audi Seat Skoda VAG HEX V2 support reprogramming, full chips : ATMEGA162 + FT232RQ + 9241 + 16V8B +ATA6561... Special thanks Kolimer for his support!!!
In that case I suggest to remove the STC completely, don't worry about the other components.
@kolimer:
I am working on VCDS protocol and I might have a small improvement to your tool EEType.
As you know sometime the AVR doesn't respond when requesting fw version.
It is mentioned here the cable must be "unlocked".
But in fact this is because cable is in some other mode (lets call it "canbus" mode).
You can send the following command to put the cable back in "command" mode :
-> 53 04 A0 F7
<- 4D 04 FE B7
After you sent this command you can request firmware version again
Also, for completeness, the following command will put the cable back in "canbus" mode:
-> 53 04 B0 E7
<- 4D 04 FE B7
Feel free to contact me to discuss this protocol if you're interested.
Rgs H2Deetoo
seal777 (24th February, 2019)
There is possible to run vcds software from PC (NR.1) with the cable plugged into another PC(NR.2) using a internet connection with a remote/vpn software like Teamviewer?
Same questions for flashing Atmega via usb in the same situation: interface connected on PC NR.1 and running software(VAGCOM_EEWRITE) from PC NR.2? Pc.s conected togheter via a wirelles network using Teamviewer or another software?
Hi forum!
I'm looking into buying a VAG-COM cable for my 2016 Skoda Superb, but I dont want to spend $199 for a cable.
Since it looks like there are many bright heads here, is there a cable you can recommend? I'd like to use Ross Tech VAG-COM 17.8 - need a cable to which is compatible with this software.
Look post #5316 for example
T_ac_S (19th November, 2017)
hi i need help vcds loader blocks 91% in Windows 8.1,
i have uninstalled vcds loader and vcds 17.1.3 remains the same.
Hi, you could try use newer vcds loader v1.10 to try , EST software this period not work very well, waiting for update newer
