Hi friends
I had also bought an stm32f405 "supposedly" with possible update, using it only with its charger and software provided, after 6 months of use (without ever antivirus or web) the cable is is blocked all the LEDs light up, when I do a firmware restore (provided by the seller) it reaches 100% flashing then indicates that it is blocked.
So i tried other older firmware , more recent... still blocked It also has the 8 pin chip on the back of the PCB, in short i think the only solution would be to encourage the king Badrax to help us keep the cables up to date. another STM32F405 but for how long will it be used ?
HaynesPro online + 2022.02a version available, message for where to get it!
Col19 (30th April, 2024)
- [COLOR=var(--text-normal)]Okej guys first i have atmega it works with my golf 5 and an audi a6 c7 but not C8 so i buy the more expensive one from ali like 80 dollar and now im angry i got the STM415 instead of STM 429 chip i cant do even secuirty access with it i can with atmega [/COLOR]
[COLOR=var(--interactive-normal)]
[/COLOR]
[/COLOR]
[/COLOR]
[/COLOR]
[07:08][COLOR=var(--text-normal)]So i need a good seller plss i dont trust everyone they allways send you the wrong chip when i but this in the discritpion its says stm429 but i got 415 i can use it but secuirty access dont work i can user it with out loader the 415 thats the nice thing
[/COLOR][COLOR=var(--text-normal)][/COLOR]
I have vcds hex-v2 STM32f405 and I want to run it. What loader will be good for the interface and vcds version,
and will it work with vcds AKP Polish.My vcds is on a better pcb, better version
VIIPlusLoader 08.023.11 or VIIPlusLoader 08.024.11 version VCDS ?
Mega Download link:
https://mega.nz/folder/CIk2UaLI#ORjmykOKTDgGkFClCYpHRA
Changelog:
1. VCDS V08.024.04 VIIPlusLoader
2. Fixed bugs
3. Add several ECU module diagnostic identifications
i just sell it in facebook marketplace i put a new order now for stm 429 from poland warhouse
Hello! I am sure that I have a harware problem with Vcds Clone ARMSTM32F429 Fly Loader 08.024.04. To any VAG car with CAN (ignition or engine on) give the mesaage CAN TESTING and can not connect to the car. Contacted Fly team and told me to send back the interface. From Europe to China and back to me it is nonsense. Can you help me with some stepts that I can check myself on the PCB? ThanksIMG_9994.jpg
I understand that my vcds will work with vcds AKP ?
@audiobesst1111
yes, you can use latest VIIPlusLoader and https://www.vcds.eu/downloads/VCDS-A...-Installer.exe
but did you sure that you cable working? your MIC2920A look as fired out
Hello ,friend
Could you share with us photos of your vcds cable purchased from this reseller? And also license info on vcds software release 23.11 about tab?
Is it registered registered in FLY V2, V2 or nothing? or @drdahmani2 cable https://www.digital-kaos.co.uk/forum...8&d=1713527619
and do you access long coding and sfd?
THANKS
