VAG-COM/VCDS EVERYTHING - Page 322
Page 322 of 844 FirstFirst ... 222272312317318319320321322323324325326327332372422822 ... LastLast
Results 4,816 to 4,830 of 12650
  1. #4816
    Feb 2016
    Moldova
    If somebody need configuration file for Xprog, for flashing VCDS HW46. Byte is the same, only is mirorred in oposition to AVRdude.
    One remark: My VCDS is HW46, 100% same element in foto from Info.pdf, Atmega - 2 track is not connected to GAL. But Kolimer soft for detect HW show me - HW44. Anyway I flashed with Xprog as HW46 and test tomorrow. On bench is ok, valid licence, firmware - 1.96.
  2. #4817
    Apr 2017
    I bought the same one ( "17.1") at the same place 3 weeks ago.
    You just have to install the VCDS version 17.1.3 from kolimer's zip and run the launcher "VCDS 17.1.3 cracked"
    You dont need any re-programming for the components (ftdi or atmel) !
    Works like a charm with my Skoda Superb 3V (many options added ..)
    @ Kolimer: Just a question about the version of the harware used inside the interface you preconized as best hardware from ODB2cartool.com, you tell it is a HW 0x46 but i can see that the pins 1 and 2 of the GAL driving the timings of the K interface are connected to the pin 34 and 35 of the ATMega ?c .... as for a HW 0x44 ! Were is the truth ? It could be annoying if we need one day the K interface.
  3. The Following User Says Thank You to rfasic For This Useful Post:
    EpicFail78 (24th April, 2017)
  4. #4818
    Feb 2016
    Moldova
    And anyone can confim locks bits, is FF? Because in old VCDS locks bits is CC. But in Info.pdf locks bits is 3F. Were is the truth ?
  5. #4819
    May 2010
    Wrong post..
  6. #4820
    Feb 2017
    Quote Originally Posted by Moldovan1 View Post
    FF means no locked for reading
  7. The Following User Says Thank You to kolimer For This Useful Post:
    Moldovan1 (25th April, 2017)
  8. #4821
    Feb 2017
    Quote Originally Posted by rfasic View Post
    Hmm, now I'm not sure. The only I'm sure that there are two versions of HW. See two schematics attached, but I'm not sure which one is HW44 and which one is HW46. I have no old car with no CAN and with K1&K2 lines to test it.
    Sch.zip
  9. #4822
    Feb 2016
    Moldova
    So, FF is right locks fuses for fw1.96?
  10. #4823
    Mar 2017
    I have test it. Thanks for hint. But not works for me . Too many conection error in my old golf 4.
    No can !
    Hardware Version 0x 46
    Firmware 1.96
    Any have a cracked exe for German version 1.7.3.1?
  11. #4824
    Sep 2016
    EU
    Hello. Need Vcds 12.12.3 china clone software. thx in advance
  12. #4825
    Nov 2016
    Hi. I write 17.1.3 kolimer 0x46 https://goo.gl/photos/7S6NMTUNLojr9YRp9 My pcb https://goo.gl/photos/HogpGRSVaqYkhDoZA and I'm have problems with this https://goo.gl/photos/AoTpjgJCa6JCJwRy8 I'm don't see fault codes, dynamic logs works excellent in kline and CAN cars.
  13. #4826
    Feb 2016
    Moldova
    UP. FF is right locks fuses for FW1.96? I unterstand that locks fuses is only for posibility of read the fw, but I also know that incorrect locks fuses can confuse right execution of the firmware. Thanks in advance for response!
    EDIT: Kolimer confrimed what correct locks fuses is FF. Thanks!
  14. #4827
    Feb 2013
    Quote Originally Posted by gumacz100 View Post
    Your problem might be the FTDI -RQ on your PCB, as I read on earlyer pages, kolimer's dump are for FTDI RL type.
  15. #4828
    angelx431's Avatar
    Sep 2010
    BG Sofia Madrid
    Search EPT file FT232BL for version 17.1.3
    Thanks!
    Gasoline in the blood!
  16. #4829
    Feb 2017
    Quote Originally Posted by angelx431 View Post
    Thanks!
    You are not right. FT232RQ and FT232RL are both same HW only in different package http://www.ftdichip.com/Support/Docu.../DS_FT232R.pdf
    FT232RQ - package QFN32
    FT232RL - package SSOP-08
    17.1.3 should work on both.
  17. The Following 4 Users Say Thank You to kolimer For This Useful Post:
    alexm1 (25th April, 2017), angelx431 (24th April, 2017), Rebus77 (20th February, 2019), yahia1908 (16th May, 2017)
  18. #4830
    angelx431's Avatar
    Sep 2010
    BG Sofia Madrid
    Quote Originally Posted by kolimer View Post
    Not FT232RQ and FT232RL. My VCDS FT232BM. Search only BL, BM
