Results 1 to 4 of 4
    Apr 2022
    Default VW Passat B6 ESL checksum error
    Address 25: Immobilizer Labels: 3C0-959-433-25.clb
    Part No SW: 3C0 959 433 AR HW: 3C0 959 433 AR
    Component: IMMO 043 0383
    Revision: 00043000 Serial number: VWZCZ000000000
    Shop #: WSC 131071 1023 2097151
    VCID: 7AFB47EF35DF509FD8-802E
    Subsystem 1 - Part No: 3C0 905 861 H
    Component: ELV 028 0380
    3C0905861H ELV 028 0380
    1 Fault Found:
    02861 - Electronic Steering Column Lock Check Sum Error
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 4
    Fault Frequency: 21
    Reset counter: 163
    Mileage: 196847 km
    Time Indication: 0
    Date: 2063.14.31
    Time: 20:15:11
    This car sometimes refuses to start. It shows something lime "Steering Lock malfunction" on the instrument cluster. The internet is flooded with instructions on how to solve the common issue with the Passat B6 (CE) ESL replacing the microswitches fitted inside it. Frequentily, the depicted error code shows up with another 2 or 3 error codes related to the steering lock, like these:
    02818 - Steering Column Lock; Enabling for Electronic Ignition Lock
    02811 - Control Module for Electronic Steering Column Lock (J764)
    None of these show up in the car I am facing issues with, so I am a bit skeptical about the posibility of solving it just by replacing the switches. Could it really throw JUST a checksum error due to a switch malfunction? Sounds more like a micro/ eeprom error to me. Any ideas?
    super jumbe's Avatar
    Livingstone
    I tried programming new steering always fail, just get the full kit from ebay your problem solve, you only need steering lock, ECU, comfort module, key.
    right here right now
    One option is new lock is only approximately €100, have had some with this same dtc and replacing esl motor has solved the problem
    I have also replaced microswitches but never had any with relay failure.
    Hope this helps.
    Sent from my SM-G988B using Tapatalk
    Oct 2022
    Hi all,
    i would like to say that there is alternative fix for this. Someone might find it helpful.
    When you meet this kind of problem and OBD diag. read is showing codes for "Steering wheel lock failure/faulty"
    Solution:
    you can just get new or used steering lock that works (be careful that its the same numbers as your old!)
    on your car:
    FIRST - disconnect your battery!
    take the whole steering wheel apart to acess the ESL. take it apart too....
    desolder two memory chips from the old board and solder them onto your new/used locks board.
    when you make it all back together the fix isnt finished...
    1.) connect battery, ingition on
    2.) connect diag. via OBD and erase all the faults.
    3.) unplug diag.
    4.) start the car B-)
    Works fine, tested. Hope works for you too.
    Any questions go ahead.
  5. The Following 2 Users Say Thank You to dtxcrtt For This Useful Post:
    line44 (3rd June, 2023), wuza (26th March, 2023)
