Results 1 to 7 of 7
    Jul 2017
    Default 5008 seat belt airbag error message
    Hi there, I have a bit of a problem and wonder if any of you can help.
    Some time ago I replace both seat belt airbags and cleared crash data from airbag module.
    On the passenger seat belt there is a pretensioner and I put a resistor there. All good and no problems.
    Yesterday I went over a bump in the road quite hard and now I have the airbag light on with also a message saying seat belt airbag has a problem.
    Both seat belts are good. I have replaced the resistor in the pretensioner just in case but still light and message are on.
    Did this bump caused crash data in the airbag module and I need now to reset the module and clear crash data?
    What else could be causing this error message and light on?
    This is for a peugeot 5008 (2010)
    Many thanks in advance
    megabits's Avatar
    May 2017
    South America
    Quote Originally Posted by zecopeca View Post
    Replace the seat belt tensioner. Then reset the crash file. The error was probably recorded in the file. For more accurate information, it is best to post a photo of the SRS module label.
    In case my help has been useful do not forget the magic buttons. ( Thanks and * Reputation ) !!!.
    ATTENTION!!!
    Attempting to clean files is only to help members. By using these files, you agree to assume the consequences and are aware that all liability for any damages is entirely yours.
    Thank you!
    megabits.
  3. The Following User Says Thank You to megabits For This Useful Post:
    zecopeca (29th June, 2018)
    Jul 2017
    Thanks Megabits
    Here is a pic of the SRS module.
    slick_dick's Avatar
    Essex
    dont use resistors always best to replace components
    and you would really need to diagnose the issue with a good scanner in order to know exactly what the issue is
    “There's nothing more dangerous than someone who wants to make the world a better place.” ― Banksy
    Jul 2017
    Yes resistor is temporary until I find a second hand one. Is there a way to check if there is crash data in the SRS module?
    slick_dick's Avatar
    Essex
    diagnostics only
    read faults and post here
    use a scanner to find the exact cause
    Jul 2017
    Ok thanks all.
    I have replaced pretensionner and cleared crash data in the airbag module. Light is no off and all working.
    Many thanks
