Page 2 of 2 FirstFirst 12
Results 16 to 28 of 28
  1. #16
    Mar 2018
    Quote Originally Posted by lion0304 View Post
    Because no any tool can do all your job.
    But you can start with that
    Isn't it a case of reading the eeprom using ktag and ksuit. Then use some other software to modify the files read. Then write them back with ksuit?
  2. #17
    lion0304's Avatar
    Oct 2014
    Quote Originally Posted by Inked View Post
    It depending what material you work on
    Envoyé de mon LG-H815 en utilisant Tapatalk
  3. The Following User Says Thank You to lion0304 For This Useful Post:
    Inked (17th August, 2018)
  4. #18
    Mar 2018
    I know it won't work with 100% of Ecu's but it does seem to work with a lot of them.
    What is the most user friendly software to use to modify the files before writing them back ?
  5. #19
    Mar 2018
    I've just discovered FGTech clone.
    Is this better than Ktag?
  6. #20
    lion0304's Avatar
    Oct 2014
    You will need both and more. But starting, you can buy FGtech 54, Ktag.
  7. The Following User Says Thank You to lion0304 For This Useful Post:
    Inked (18th August, 2018)
  8. #21
    Mar 2018
    Thanks again for all your help
    What can FGTech do that k-tag can't?
    From what I've been reading, FGTech seems to be ktag and kess all rolling in to one.
  9. #22
    Mar 2018
    Anyone ??
  10. #23
    droidwayne65's Avatar
    Aug 2015
    North America
    You wont find a cheap programmer that will do everything you want but a good Carprog clone covers quite a lot. Be better to spend a little more for a good clone than spending time reworking it.
  11. The Following User Says Thank You to droidwayne65 For This Useful Post:
    Inked (21st August, 2018)
  12. #24
    Mar 2018
    Quote Originally Posted by droidwayne65 View Post
    So are you saying you would choose carprog over ktag, kess and FGTech?
  13. #25
    lion0304's Avatar
    Oct 2014
    You need to learn first. Learning isn't just asking what, why and how.....
  14. #26
    Aug 2015
    North America
    I use all three and each is good at what it does but if you looking for a Jack-of-all-trades type programmer, Carprog comes closest to it. It can't do what those three ECU programmers do and they can't do what it does. When all's said and done, you're gonna have to get complementary tools.
  15. The Following User Says Thank You to droidwayne65 For This Useful Post:
    Inked (24th August, 2018)
  16. #27
    narkeleptk's Avatar
    May 2017
    USA
    I think the best tool for you to start out with was already posted.
    TL866
  17. #28
    Mar 2018
    Thanks for the reply.
    I'm really leaning towards a FGTech clone but I keep reading that it hasn't been updated in a long while.
    Do you know when the latest clone was last updated as I can't find any information anywhere?
    Also do you know if it would read SID211 ECU's?
