Page 3 of 5 FirstFirst 12345 LastLast
Results 31 to 45 of 74
  1. #31
    obdsystems's Avatar
    Oct 2013
    U.K, not the E.U.
    trouble with most chinese tools
    Definitely 'unproven' chinese tool your using. Your money now has to be paid buying FEM unit
    You were a test dummy mate. it's not nice but true. I rather spend it towards Autohex or Abrites
    I am a FUD
  2. #32
    yes try using ista p, when it loads click replace unit fem, let it config and code and see what happens, put original eprom data back in chip?
  3. #33
    If you disolder eeprom check carefully all connections. If all ok get new 95128/95256, load back up and start all over again.
  4. #34
    Apr 2016
    holland
    hahhahahhahaha and bmw g cars also bricked
  5. #35
    The possibility of using ista p to fix the FEM is also mentioned in user manuals for the other tools, so this step is not specific to the Yanhua tool.
  6. #36
    obdsystems's Avatar
    Oct 2013
    U.K, not the E.U.
    can't believe anybody could damage an 8-pin chip - unless u follow those youtube videos
    Need proper de-soldering equipment even for simple stuff.
    replacing chip won't help -
    I am a FUD
  7. #37
    drugowaz's Avatar
    Mar 2015
    Lithuania
    What is you technik to desolder?
  8. #38
    Jun 2013
    I see on various of videos, they only using clip to read/write the info.
  9. #39
    Oct 2017
    BMW
    Quote Originally Posted by Weasel3 View Post
    Only crazy uses chips to read eerpom )))
  10. #40
    Talking
    Quote Originally Posted by TVO View Post
    Use to disolder but now I'm big crazy. Using only clip
    Whole process takes 10min.
  11. #41
    Oct 2017
    BMW
    Quote Originally Posted by qwojtus View Post
    Its only your choice )) how to do
  12. #42
    Quote Originally Posted by obdsystems View Post
    I see mate you pretty confident chip = €2 FEM = €600
  13. #43
    Oct 2017
    BMW
    Problem to desolder eeprom ? The processor is better to cover with foil
  14. #44
    I have no problems mate I try to help.
    I tested few FEM and possible to damage the chip.
    - using official BMW EXPLORER table connection you will burn the chip.
    - using cheap programmer with clip ( no disoldering) you will kill the chip.
  15. #45
    Oct 2017
    BMW
    Tell us how u can burn chip using official BMW EXPLORER table connection ?
    Reading chip we can kill eeprom ?
    I see u are realy crazy man ))) Or may be i dont understand what u are talking about.
    I always use hot air and no problem .
