Results 1 to 3 of 3
Thread: Ecu swap
    Oct 2010
    Default Ecu swap
    Hello dk members, I wanna ask you about if it’s possible to swap ecu 0281011263 edc16c3-9.18 to 0281011701 edc16c34-2.30.
    With 0281011263 car no start because p1603 is present
    I found 0281011701 from same model of Ford Focus 1.6 tdci and change with dashboard and transponder
    Now the car starts but stop in few seconds and show dtc p1181
    I don’t know if dtc shows because diesel pump is damaged or if ecu are not compatible with old
    Any suggestion are wellcome
    Joze
    Enviado desde mi iPhone utilizando Tapatalk
  2. The Following User Says Thank You to joze For This Useful Post:
    Abdssamed1992 (23rd March, 2018)
  3. #2
    MartiLer's Avatar
    Dec 2016
    Where are the dumps?
  4. The Following User Says Thank You to MartiLer For This Useful Post:
  5. #3
    Louislesinge's Avatar
    Jun 2017
    French Jungle
    ECUs are not hardware compatible, you can not swap them.
    Greetings,
  6. The Following User Says Thank You to Louislesinge For This Useful Post:
