Results 1 to 11 of 11
    May 2017
    usa
    Default 2005 grand prix odo program dsp3?
    is there a way i can program odo with dsp3+ i have located chip in the dic and tried silverado selection as chip should be the same tried the clip and can save and read it but error comes up when tries to write? thanks in advance
    Mar 2017
    If you can save the dump, post it here. Do you have another programmer like upa to write the modified dump back into the eeprom?
    May 2017
    usa
    i do not have another programmer
    clusters's Avatar
    Mar 2015
    Canada
    Unsolder the chip and see if it will program.
  5. The Following 2 Users Say Thank You to clusters For This Useful Post:
    narkeleptk (27th May, 2017), reuse (27th May, 2017)
    May 2017
    usa
    ok will try that
    epd1221's Avatar
    Nov 2011
    usa
    Never work with dsp3 but check it might be possible by obd.
    May 2017
    usa
    obd only goes up to 2003 yes it did work success THANKS CLUSRTERS JUST ALOT MORE WORK
  9. The Following User Says Thank You to reuse For This Useful Post:
    clusters (27th May, 2017)
  10. #8
    clusters's Avatar
    Mar 2015
    Canada
    It's not always just pushing buttons, get used to it.
  11. #9
    May 2017
    usa
    so most chips you can leave on board why do you think this one is different?
  12. #10
    clusters's Avatar
    Mar 2015
    Canada
    Clusters are usually not a problem, some GM BCM don't work in circuit. I guess this unit is one that doesn't.
  13. #11
    XmoDDeR's Avatar
    Mar 2011
    putting salt on leeches, one grain at a time!
    works with dsp3 both ways and manual with chip incircuit , learn methods and tools
    Reading is fundamental, asking is easy............................
