Results 1 to 15 of 17
    Jan 2016
    Default Can't read 28F400 flash with TL866CS
    Like topic says...
    I have two chips. Both 29F800 and 28F400.
    One is Intel AB28F400 B5B and other is AMD AM29F800BB. In both case, when I select the proper chip in MiniPro and put the proper adapter (yes I have adapter.... SOP44 on top of TSOP48), it just says chip ID FFFF FFFF and says can't read.
    I have a willem SOP44 adapter on order, but it wont get here until next two weeks.
    Is there something wrong with my mini pro?
    Jun 2013
    Check pins whether connect properly to the socket. i have read & write same chip with minipro without any problem.
    May 2013
    Hi therer
    Clean the pins on FLASH chip again and again. SOmetimes help by pressing on chip while trying to read.
    Sep 2016
    portugal
    Quote Originally Posted by Deplore View Post
    Like topic says...
    you search on the net had checked ic of adptador board the pine 1 not ta connected is isolated under the adptador the circuiro is isolated i not le the 29f400 nen the 29f200 cuanto the 28f512 already tried everything i is not posivel read nen write the problem and not sof the hope I help my esperiencia
  5. The Following User Says Thank You to juanes 3 For This Useful Post:
    typhoon666 (8th October, 2016)
    HELLO
    yo must desactive "check id" in option
    filutek's Avatar
    Silesia
    Problem is adapter .....
    no connections on the board.
    Jul 2014
    I had the same problem several times.
    Cleaning the legs always helped.
    If you can't write disable "device id". Write a file than activate back "device id" and read and write again to be sure is not corrupt.
    raceshadow's Avatar
    Mar 2016
    Czech Republic
    I have this adapter and no problem.
  10. #9
    Jun 2009
    Quote Originally Posted by raceshadow View Post
    Have the same adapter but can not read a AM29F400BT from a VAG ECU. Error
    Programmer is a TL866 II Plus
    When i click away "check ID" i can read it but readout is shit
  11. #10
    raceshadow's Avatar
    Mar 2016
    Czech Republic
    Quote Originally Posted by chli1976 View Post
    You have a bad contact between the chip and the programmer. Try pressing your finger down on the chip.
    IF I HELPED YOU, PRESS THANKS AND REPUTATION BUTTON!!!
  12. The Following User Says Thank You to raceshadow For This Useful Post:
    chli1976 (26th September, 2018)
  13. #11
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    try also to clean legs of solder and after with cleaner....
  14. The Following User Says Thank You to figani For This Useful Post:
  15. #12
    Aivis3's Avatar
    Sep 2016
    Latvia
    LEGS, LEGS, LEGS
    Need to clean legs. Sometime need re-insert chip in adapter
    If helped - "Thanks" and "Reputation" please
  16. #13
    Sep 2016
    Donetsk
    see adapter
  17. #14
    Apr 2018
    Today i have the same issue. Clean legs with desoldering wire + sandpiper 600 and all OK.
  18. #15
    MOHCIN2's Avatar
    Feb 2013
    IN GOD'S EARTH
    Try with this information to repair the socket and uncheck the option of verify id
