Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 46
  1. #31
    Jun 2014
    Serbia
    Hello, I need help with Chevrolet Aveo 2008. all keys lost. I try to add key with SBB but without success.
    After that when I read dump from immo box I saw that all keys are erased.
    ID from new transponder ID48 is 04 56 AB F5
    Can somebody help me with this please?
    Thanks in advanced!
  2. #32
    lion0304's Avatar
    Oct 2014
    Quote Originally Posted by Cesarec View Post
    Thanks in advanced!
    Try this file, write as 16bits
  3. The Following User Says Thank You to lion0304 For This Useful Post:
    Cesarec (21st March, 2018)
  4. #33
    Jun 2014
    Serbia
    Quote Originally Posted by lion0304 View Post
    Thanks, I will try and report.
  5. #34
    castin's Avatar
    Oct 2015
    Try precode transponder (im use Tango) . Im not precode id48 and after write car dont start. After precode all ok.
  6. The Following User Says Thank You to castin For This Useful Post:
    Cesarec (22nd March, 2018)
  7. #35
    Jun 2014
    Serbia
    Thanks to all. Problem solved.
  8. The Following User Says Thank You to Cesarec For This Useful Post:
    lion0304 (21st March, 2018)
  9. #36
    lion0304's Avatar
    Oct 2014
    Quote Originally Posted by castin View Post
    ID48 need to be locked to start engine.
  10. #37
    Jun 2014
    Serbia
    Thanks mate, that was the problem. ID48 need to be precoded before learning key. I write back ori dump and add key by obd.
    To lion0304:
    "ID48 need to be locked to start engine"
    ID48 must be unlocked before learning.I was trying to add transponder manually and locked it from dump but without success.
  11. #38
    lion0304's Avatar
    Oct 2014
    To lion0304:
    If you add transponder to dump by prorammer or manual, after added, transponder need to be locked.
    And over obd, it need precode before.
  12. The Following User Says Thank You to lion0304 For This Useful Post:
  13. #39
    Jun 2014
    Serbia
    Yes that's right.
  14. #40
    Quote Originally Posted by ninja123 View Post
    Glad to be of help mate, I had this same problem just last week, so all info was fresh in my mind!!
    Nice to get a reply too!!
    ninja
    Same problem... was useful dump from ninja 123 for learn somethink but it is password protected Any help? my dump is ok but the zone about key is FF... sames that keys are been deleted
  15. #41
    Dec 2018
    Hi, i have a chevrolet aveo 2007 wit a immo problem and i think is a bad dump fom RL56. Frst i tried with T300 and not work and second time with fvdi v2018 in KEY tool section but no success. Please help me with a good dump. key 1 : E1648337. KEY 2: B630E417. Thank you
  16. #42
    hi sir
    please i need help if you can
    i have suzuki swift+ 2008 with immo i850 like chev aveo immo , maybe immo dump not good i hane sbb and gscan2 and mpv pro i can not re sycronic immo error connection this is immo dump please check it and repair i read it as aveo 93c56
    with my best regards
  17. #43
    May 2017
    argentina
    CONTRASEŅA POR FAVOR ?
  18. #44
    Nov 2016
    hello ,i tray to add new key delete old (lost).aveo 1.2 my 2010.used blak id48 .read rl56(96c56) with programer. open dump over fvdi tah key tool and add new blank transponder. will car start ? the car is 50km from me .do i need to lock id48
  19. #45
    Oct 2018
    Hi guys I have a similar problem can t300 sync immo with ecu
