Clutch switch? Check abs and hvac for errors
Hi people,
We have here car volkswagen jetta 1.6tdi from 2011 cruise control dont work
We change control switch but also fault
I have dtc P056800 cruise control signal fault permanent.
I adapt it but no work.
Maybe module broken?
Someone tips?
Verstuurd vanaf mijn SM-G955F met Tapatalk
Sedat Garip
Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
Diesel + petrol All cars
Manual Adblue dpf egr Opf tested working solutions
Belgium
With Kind Regards,
Don't forget hit thank button if i helped.
Abs error is ok there are no fault and switch working.
Module?
Sedat Garip
Belgium
With Kind Regards,
What happens if uou knock off 00 of fault code and google it?
I had a transporter T5 a while ago with a fault cruise control switch. Ordered one from TPS who told me there was only one switch for the van. Still didnt work. Turns out there were 4 different switches. TPS full of shite. Got the right one eventually. Check live data on VCDS because what it says is right. If you press up and VCDS says u pressed down for example you will have wrong switch. Assuming there is more than one for your vehicle.
V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
