hello try
FJ5J-VALQ-F9VM
but not right for all das version ,for this code need down 1.2012 das version
regards
hello try
FJ5J-VALQ-F9VM
regards
Hi! After logging in to the SAM all right.
Thank you!
Hi! . Can you please calculate the code for immo synchronization for DAS . Vin WME4540301B034361.
Car don't start after discharge the battery . ECU MEG is fault P0513 Immo problem in SAM. In SAM B1726 and B1731. I tried with the Smart TAN calculator but the code generated is wrong. Thanks in advance.
hello try
9KM2-R988-4DXH
mariusf11 (20th April, 2015)
Thanks a lot. The car started. You are great.
hi! Can you calculate the synchronization code for VIN WME4540311B014347. i have the same problem. thank you !
try F471-T948-3DPM
report please
gombos (14th July, 2015)
not working
everything is original. the vin is good . you have any other solution?
sorry not not have other
Hi! I need code for immo synchronization for DAS . Vin WME4540311B109653.
Car don't start after discharge the battery . ECU MEG is fault P0513 Immo problem in SAM. In SAM B1723
Regards.
Hy!
I have almost the same problem. Car starts only when it is cold outside. When I leave the car outside in the sun and gets hot is not starting and gives P0513.
It is VERY interesting....
please i need pass code to enter SAM of smart car vin-- WME4540311B020926.
THANKS
Hello
try F35R-XA8Q-79VM
report please
