Page 213 of 450 FirstFirst ... 113163203208209210211212213214215216217218223263313 ... LastLast
Results 3,181 to 3,195 of 6745
  1. #3181
    Quote Originally Posted by MVVL View Post
    Mercedes Instrument
    HI, MI cant find password of takes too much time...
    regards ficho
  2. The Following 5 Users Say Thank You to ficho For This Useful Post:
    daxxer (22nd June, 2017), dritan (21st June, 2017), keyantic (22nd June, 2017), MVVL (22nd June, 2017), rola1971 (22nd June, 2017)
  3. #3182
    Mar 2015
    UA
    ficho, MI reads this data in the swap.
    Dealer Hash: AB E8 09 01 20 8A B5 6C - 6CB58A200109E8AB
    Transport protect hash : 5C 7C BA ED F0 01 E9 C2 - C2E901F0EDBA7C5C
    Is it possible to count? Thank you.
  4. #3183
    You didn't answer my question, MI didn't find the password or what was the problem why you requested erase pass here ?
    BTW Here is you requested hash:
    6CB58A200109E8AB <- B197274988510F7E (You have to swap bytes as you know).
    regards ficho
  5. The Following 2 Users Say Thank You to ficho For This Useful Post:
    daxxer (22nd June, 2017), MVVL (22nd June, 2017)
  6. #3184
    Mar 2015
    UA
    ficho I need to reset the ISM . On MI I will buy a token, and I can calculate the password myself. Thanks.
    7E 0F 51 88 49 27 97 B1 - OK
    ficho - thanks
  7. #3185
    ficho - thanks
    so if i understand correct you have request the psw because you did'nt want to buy a Token
    and not because the MI could'nt calc the psw. correct?
  8. The Following User Says Thank You to vageric For This Useful Post:
  9. #3186
    Mar 2015
    UA
    I buy tokens, but in the past few days I had to reset 7G and 2pcs ISM. Tokens are over, they could not pay for new tokens yet. I will not ask for more help in the calculation, since the token is inexpensive. ficho many thanks for the help.
  10. #3187
    Jun 2014
    ankara-turkei
    Hello MVVL, here is your dealer password. and please note that your hash is reversed (probably taken by Mercedes Instrument)
    Dealer Hash: 875B7F1233DDD7EC
    Dealer Pass: D2B0CE8EBE081E32
  11. #3188
    Mar 2015
    UA
    Thank you, but I already decided my problem. MI counts the passwords correctly.
  12. #3189
    HI,
    MVVL, OK no problem, did you request this hash also I didn't notice?
    AS I can see caliskan71 has replied:
    regards Ficho
  13. The Following 2 Users Say Thank You to ficho For This Useful Post:
    daxxer (22nd June, 2017), habbyb (23rd June, 2017)
  14. #3190
    Mar 2015
    UA
    Hey. ficho I did not ask for anything else, you gave me the password - I did the job. caliskan71 can not understand something, although thanks to him that he wanted to help.
  15. #3191
    lush29's Avatar
    Oct 2015
    Hi. I am sure this question is been asked before, apologies if so. Have an 2005 w203 lost keys car is far away and i will like to know how many tokens do i need for lost key? Or tokens are only for bga key? Thanks
  16. #3192
    auto techniek's Avatar
    Mar 2017
    W203 till 2002 is K line and you don t need any token.
    After that year it wil recognised not as W203 but some times as W211 or W209.
    If the lost keys can be calculated you need 2 token.
  17. The Following User Says Thank You to auto techniek For This Useful Post:
    lush29 (24th June, 2017)
  18. #3193
    tokens are only for bga calc.
    w211, 203, 209 are all 912/9s12
    just read the mcu with a programmer and make new keys.
  19. The Following User Says Thank You to vageric For This Useful Post:
    daxxer (24th June, 2017)
  20. #3194
    From reading these posts it looks like tokens are used every time you connect to their server regardless of make, model, bga or NEC.
    But if you pull the eis and read the dump then obviously no token.
    You are using the tokens to do it faster by not having to pull the eis, having to read it and less chance of damaging the Eis.
  21. The Following User Says Thank You to keysmith For This Useful Post:
    lush29 (26th June, 2017)
  22. #3195
    Sep 2016
    South africa
    Hi ficho I. Need erase PW Special key: 20DE29D426C5B91F
