Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
  1. #16
    Aug 2010
    i found tow cars died by others locksmith because they use x100 pro to program this type and result send the them to dealer .
  2. The Following User Says Thank You to wd bau For This Useful Post:
    KEY GO (15th August, 2018)
  3. #17
    Sep 2016
    SOLVED
    it is my mistake
    i do this to program key
    unlock steering with skp900 and after that i program key
    but i forgot an important think to end programming procedure
    the solution is
    there are a small button near twist ignition u must push in and turn ignition to lock position
    steering will be locked again
    and after that all is fine
    thanks to all friends who help me
  4. The Following 4 Users Say Thank You to KEY GO For This Useful Post:
    klesk1986 (15th August, 2018), kronk92 (15th August, 2018), lion0304 (18th August, 2018), paul_12345 (15th August, 2018)
  5. #18
    lion0304's Avatar
    Oct 2014
    Quote Originally Posted by KEY GO View Post
    SOLVED
    it is my mistake
    the solution is
    Do you succes for programming the prox function ưith SKP900?
  6. #19
    It is skp900 still update or developer stop update this tool?
  7. #20
    newone's Avatar
    Oct 2016
    no updates anymore,v5 was the last one
  8. The Following User Says Thank You to newone For This Useful Post:
    Brat (18th August, 2018)
