    May 2014
    LIthuania
    Default citroen c3 2002y 1.4 hdi dtc remove p1113 p1198
    hi mates please remove fault codes p1113 p1198 car is citroen c3 2002y 1.4 hdi sid 802 read made as sid 804 but as I found out is same ecu . thanks in advance
    May 2014
    LIthuania
    anyone can help ? I add read in boot mode cause first one was obd read thanks in advance
    bobolin4o's Avatar
    Bulgaria, V. Tarnovo
    Sorry, but those errors you cannot mask just like that...
    How will work the engine if the rail pressure is improper???
    Regards!
    May 2014
    LIthuania
    car drives normally but sometimes goes in limp mode and after few seconds goes off and drives good . this happens few times a day
    bobolin4o's Avatar
    Anyway...
    Fix the problem, how it should be fixed!
    May 2021
    Hello Tiugrikas, I know this is a very old post but do you mind sharing how you fixed the problems with your car? I'm having the same problem with my C3. Thanks!!
