The shitest tool I have ever bought ... completely useless
Digimaster3 Mileage Correction Tool only 799USD
DigiMaster-III is the third generation multi-functional Automobile data adjusting equipment.
It bases on a high performance hardware platform which takes high-speed CPLD and the ARM11 processor as the core device. Seven inch LCD touch-screen with high resolution makes its interface easy-used.
Working with various types of adapter you can easily achieve odometer correction Audio decoding airbag resetting engine ECU resetting IMMO, programming key for Benz and BMW etc.
It is applicative for all types of data processing such as OBD connection, dashboard soldering, CAS-BDM. It contains the advanced technology of programming new keys for BMW and Benz, CAS-BDM reading/writing and resetting, 35080V6 erasure etc.
The operation interface is highly user friendly, large numbers of pictures and particular description makes your operation pleasant. Online updating and module authorization keeps you always on the leading edge of technology.
Digimaster III
OBD Socket
Volkswagen/Audi/Mercedes-Benz/BMW adjust form Diagnostic socket
NEC Adapter
Applicable to CPU free switch connecting of NEC series.
35080 V6 Adapter
For 35080 series IC erasing and writing
CAN OBD DMI
Applicable to process of some Audi A6L & A8L.and VW
LS400 Adapter
Applicable to odometer IC(457C) of LexusLS400(1992-1994)
W211 Adapter
Applicable to process of EIS ECU module for Benz E Class W221(2002-2005)
BMW-CAN Adapter
Applicable to process of CAS ECU module (odometer socket)for BMW 3/5/7 series E90/E60/E66(after 2005)
CAS-BDM programmer
Applicable to process CAS1\CAS2\CAS3\CAS4 ECU module (DG128/256/512)for
BMW 3/5/7 series
AZ60_F Adapter
Quickly read and write EIS ECU of Benz
ESLconnector
1.MOTOROLA key chio;
2.E Class W210 ESL(05E6/G72A);
3.E Class W211 ESL(05E6/0F82B);
4.CLK Class W208 ESL(05E6/G72A);
5.CLK Class W209 ESL(05E6/0F82B);
6.CLS Class W219 ESL(05E6/0F82B);
7.C Class W202 ESL(05E6/G72A);
8.C Class W203 ESL(05E6/0F82B);
29F Adapter
Old Mercedes Benz DME 29F400 and 29F800 Chip
Meter Socket
Adjust Benz\ BMW\Jaguar\Ford meter from meter socket
TMS370Programmer
Applicable to anti-theft reading for old Jetta, audio decoding for Deco and Opel.
K&CAN Adapter
1Applicable to airbag resetting via K-Cable
2 CAS module programming for BMW.
9S12 Adapter
Applicable to CAS ECU module programming for BMW 3/5/7 series of electronic
chassis E90/E60/E66 (after 2005), and EIS ECU module programming for
Mercedes-Benz S/E/C class of electronic chassis W220/W211/W203(after 2005)
Grand Cherokee Adapter
Applicable to odometer CPU of Grand Cherokee
E65/E66 Adapter
Applicable to process of CAS ECU module for BMW 7 series E65/E66(2002-2004)
W220/W203 Adapter
Applicable to EIS ECU module programming of Mercedes-Benz C/S class
electronic chassis W220/W203/W215/R230
MC711 Adapter
Old BMW EWS2(2D47J,0D46J) / EWS3 2D47J,0D46J)
MC705 Adapter
1.S Class W140 DAS IMMO ECU 05X32(0D69J)
2.S Class W140 DAS IMMO ECU 05X32(0D53J/0D62J)
3.S Class W220 EIS ignition module 05X32(1D69J)
4.CLK Class W208 EIS ignition module 05X32(1D69J)
5.C Class W202 EIS ignition module 05X32(1D69J)
6.E Class W210 EIS ignition module 05X32(1D69J)
7.ML Class W163 AAM 05X32(G47V/1D69J )
EWS-K Adapter
adjust EWS through K line
MC705E6 Adapter
MOTOROLA key chip
IAR Adapter
Write Benz key
NXP Adapter
BMW key chip and key
7936 7941 7942 7943 7944 7945 7946 7947 7952 7961
NEC KEY Adapter
Mercedes Benz S, C, E, SL, CL, CLK and CLS Class Key
OBP Adapter
Applicable to EEPROM meter, airbag ECU, audio ECU which need to be
unsoldered.
ICP Adapter
Applicable to free stitches of 93 series, 25 series, 35080 EEPROM, CPU meter,
airbag ECU, audio, ECU, etc.
Smart car engineer ,
Is it so cheap? I have never know Digimaster 3 is so cheap. As I know, it is 2000USD...
This dick head is spamming loads of forums.
V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
Yes Original Digimaster III cost a bit on 2000USD
Not bad price
where can i find this tool for that price ? and is this a good tool or a fake one as the other china tools ?
Digimaster 3 costs about $2000, not $700!
