Results 1 to 7 of 7
    afonso rico's Avatar
    guimarães
    Default syncro dme /ews mini r52
    hello to all
    e need syncro these files for mini r52
    sommeone cant hellp??
    Dec 2013
    These files should work, I think VIN and ISN (B3 9F) numbers are the same in DME and EWS. What's the problem, write more details.
    You may need DME-EWS alignment only (using diagnostic tool).
    guimarães
    car not start and the only error is the ecu engine code incorret
    Dec 2013
    Have you tried EWS-DME alignment with diagnostic tool?
    doctore's Avatar
    Nov 2015
    Colorado Denver
    tr this if you dont faind another solution make new key
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
  6. The Following User Says Thank You to doctore For This Useful Post:
    afonso rico (23rd January, 2018)
    guimarães
    Quote Originally Posted by mbi View Post
    In this car comunicaction not good ..just can diagnostic witch texa and not can pairing this car
    Enviado do meu MI 6 através do Tapatalk
    EU ESTOU COM A UCRÂNIA
    guimarães
    doctore not work your solucion ..
    same problem
    have solucion for immo off in this ecu ??
