were you able to figure it out?
I just bought one too, and i figured out how to do an 06-08 f150 but i need help with sierra? have you had any help yet
First you need to go here and introduce yourself:
http://www.digital-kaos.co.uk/forums...oduce-Yourself
Then you could share how you did the F150 please?
What year Sierra and which body style.
hero112 (6th January, 2016)
the problem with that will be that it will switch back to kms if the battery is removed and the customer won't have the DTC switch to switch it back
With the 08 f150 using the USAPROG, I used OBD and it gives you an option to save the BIN and I saved the original bin and used another bin (from an F150 that was already converted into miles) used that as the recovery bin and once that was on there. I just changed the mileage to the correct miles and I was done. I was hoping the same for the Sierra but it does not give an option to save the BIN or recover the bin.
Really? Didn't know that. The cluster eeprom should save the settings or else the trip odometer would reset too.
If that's the case, make them buy the switch and panel as part of the conversion.
I know on a 2003-2006 it saves the setting in the eeprom till changed again manually.
The guy I currently get to switch them over he just programs the clusters to USA firmware, I have just used the OBD option but I do have the EEPROM adapter, which I have never used but I can pull out the cluster and find the eeprom, It does allow me to read and write on the EEPROM, there was a 2007 silverado bin I found on here and if I put that BIN file on I can always change the mileage over the OBD. Do you think that will be my best bet?
What about the VIN and all the other truck specific programming?
USA firmware like making the odometer read in Miles?
basically it would just show miles on the odomoter reading when he would covert it, with sierra is there certain information on the EEPROM that would be required? I was just going to use a bin file that was posted on here for a 2007 silverado
or is there something in the BIN file I download from the EEPROM that would allow me to change it permanately to miles?
if you use smelecom , when you read the eeprom the tool show you 2 value to input the new odometer , first in km 2nd in mi .
it will write the miles but it will still show up in the odometer as kms.
Sort of on topic....
I just repaired a GMT800 cluster a few hours ago, it was a USA model with USA "firmware" and the speedo is in MPH. It had a DIC dash in it and the owner had it set to Km, read KM before removing it, read Km while on the bench, and still read Km when back in the truck. Those settings are written to the eeprom in the dash and won't change with a battery disconnect.
I seriously doubt GM has changed that on the GMT900, so unless you have seen it revert back with your own eyes on a battery disconnect, I would try it with your Sierra, and not believe the guy that's making money from you.
That year the truck still doesn't give a rat's butt what the cluster is doing, it just sends the info to it and the cluster displays the info according to the settings written on the eeprom. Those settings are not stored in volatile memory as far as I know, or a battery disconnect would require reprogramming. Use the DIC to change it to Miles, unplug the cluster for a few minutes, plug it back in and see what it displays and you'll have your answer. Let us know the outcome.
