Results 1 to 10 of 10
    Default 2005 Ford Explorer Sport Trac pin out
    hi members, could someone please help with the pin out
    2005 ford explorer sport trac
    MC9S12H256vpv
    I tried searching for it here but the different variations I see do not match mine
    epd1221's Avatar
    Nov 2011
    usa
    Give this a try
    Black. = ground
    White. = data
    Green = reset
    Red= power
  3. The Following User Says Thank You to epd1221 For This Useful Post:
    mojomojo (26th April, 2018)
    Quote Originally Posted by epd1221 View Post
    Give this a try
    Black. = ground
    White. = data
    Green = reset
    Red= power
    will report tomorrow. thanks
    Give this a try
    Black. = ground
    White. = data
    Green = reset
    Red= power
    I tried with your connection diagram and read it under mc912h256 secured...1st it doesnt read the mask id for 1k78x...
    I believe I matched the vvdiprog pinout with yours correctly.
    can some give me some insight thanks
    clusters's Avatar
    Mar 2015
    Canada
    I believe he may have got those a bit wrong....
    The layout is usually always the same
    GND RESET POWER
    BKGD N/C N/C
  7. The Following 2 Users Say Thank You to clusters For This Useful Post:
    jomberykaso (27th April, 2018), mojomojo (27th April, 2018)
  8. #6
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
  9. The Following User Says Thank You to jomberykaso For This Useful Post:
  10. #7
    I now siwtched the ground with blkgd and now I get an "chip not connect" messege as oppose to the wrong id being read with the first layout
  11. #8
    should I turn 180 around..i am afraid to burn the chip
    Quote Originally Posted by jomberykaso View Post
    Good Luck!
  12. #9
    FxShaw's Avatar
    Nov 2013
    Outta This World
    Try and see... you already had the ground wrong spot before anyways...i doubt u can damage it like this though.
    🔥Wacka Wacka 🔥
  13. The Following User Says Thank You to FxShaw For This Useful Post:
  14. #10
    May 2019
    Hey what’s the update I’m having the same issue with dp4 did you figure this out?
