Results 1 to 4 of 4
    Apr 2016
    GT
    Question Mazda3 - Does not mark well
    Good morning, classmates.
    Data: Mazda 3 - 2004 - 93c56
    The problem: do not mark the mph needle, nor gasoline, and do not advance the TRIP A, TRIP B.
    This is the file, I do not put another one because it carries the key pin Mazda3 2004 93c56 Original - Corrupt.rar
    This is a file of an identical board, in good working order, with this one does not start. Other mazda 3 93c56.rar
    Thank you very much!
    Apr 2016
    Did you try to remove/or removed the needles? DON'T DO THAT!
    Try to swap eeproms, i had same case...here you go one healthy dump from mazda 3 sou you can compare with your files...i think that bottom lines contain key pin.
    d1.rar
    Apr 2016
    GT
    Do not remove the needles.Thank you very much. I need to know which lines are the pin to boot
    Dr. Zoidberg's Avatar
    Oct 2015
    Talca-Chile.
    Mate, your file is a wrong, read it again, format .bin , not hex.
