Results 1 to 14 of 14
    Mar 2017
    Default Remapped file changes nothing!
    I remapped my 2001 A4 AWX 1.9TDI
    I changed:
    Limiters
    SOI
    injection duration and turbo maps
    But still not getting any increase in power, can someone figure out whats wrong with it?
    Original File and Tuned File:
    Ori and Tuned file.zip
    dominik.m's Avatar
    Jun 2009
    POLAND
    Hi. I have question also!
    Does after these changes engine work normally yet?
    Mar 2017
    Yes, but the engine makes full boost(1.6bar) and I think it doesn't reach my fuel goals, so it might be running way too lean.
    Jun 2013
    EU
    Quote Originally Posted by Cotulla View Post
    Which is not a problem for a diesel engine, also called "excess lean" engines.
    Mar 2017
    Ok, but do you know how to adjust duration maps to make more power, I guess I need way more ?? 5? or maybe 6? more?
    But do I change this in every duration map, they are not very similar?
    ohkarol's Avatar
    Oct 2010
    PL/UK
    this tune is totally wrong
    bFlash/Kess/Ktag/CMD Master
    DPF/EGR/DTC/AdBlue/ChipTuning. ------>PM
    Mar 2017
    Portugal
    have smoke on it?
    sdtsedat's Avatar
    Jan 2015
    Belgium
    You must make increase from 1000rpm!! Edc15 will not give power when you make increase after 1000rpm. Maybe 5hp..
    Wait tomorrow so i send you file and give you 100% guarantee for 30hp.
    Regards from Belgium
    Aug 2014
    Quote Originally Posted by sdtsedat View Post
    I've never heard something like this, can you elaborate?
    sdtsedat's Avatar
    Jan 2015
    Belgium
    Default Working File
    This is working 100% file.
    I make always these tuning, 101hp with this tuning 139hp on dyno (ATD engine)
    I checked you tuned file, you must feel the difference...
    Try this file, when not changes anything make log of your MAF and upload screenshot here.
    Any DTC in the car ?
    Hit thank if i helped.
    Pass on P.M.
    AUDI_AWX_MOD.rar
    Feb 2017
    Use my file and enjoy the PowerPlus Feeling
    tuned stage2 , hotstart fixed
    Jun 2016
    Quote Originally Posted by PowerPlus View Post
    Did you got your car on the dyno?
  13. #13
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    i looked at your file.Why you not changing driver wish map?
  14. #14
    Feb 2017
    Quote Originally Posted by Ignasvw View Post
    which file you looked ? and from who you get pass ?
    if you look on my PowerPlus file , you see all maps is ok and you ask me for DW map , really ? on 100% throttle stock software request 70mg. On TQ map i have 6056 , so why need to touch DW map h?!!!!!!!!!
    And Yes i change DW map on 56 , 80%
    if you have no clue, please psssssssssst all maps with limiters touched, maf map limters set to 65mg, User
    Cotulla knows how good is the file ! good power with no vibrations from low rpm!!!
    AWX have 5 gear, 228mm not strong clutch!
    Last edited by PowerPlus; 3rd May, 2017 at 03:36 AM. Reason: special infos for user Ignasvw
