Page 2 of 2 FirstFirst 12
Results 16 to 26 of 26
  1. #16
    rob h's Avatar
    May 2011
    Then F100 does the same as H100.
    Only a few US models added extra to the H100.
    F100 works realy well, and that price makes it a must have!
    Even now, having the x300dp, i still use the F100.
    Just make sure to know, what immotype to select.
  2. The Following User Says Thank You to rob h For This Useful Post:
    lion0304 (26th May, 2018)
  3. #17
    Dec 2016
    I think so add remote by hand. The same ford focus
    Procedure:
    Switch off to on with 3 times, end off.
    Press unlock button (press any remote)
    I find it on "Key Programming procedure" on App Store.
    Car locksmith
  4. #18
    Jan 2016
    Quote Originally Posted by diephieu2023 View Post
    Procedure:
    Have you tried it?!
  5. #19
    PocketHero's Avatar
    Jun 2017
    Budapest, Hungary
    Quote Originally Posted by Cr4nky View Post
    Have you tried it?!
    I think not. You have to put on ignition until it beeps within 15 seconds. It can be 3-10 times, depends on the cars emotion at the moment. If possible end with ignition on. Push button on the remote, when learned hazards are blinking. Switch off ignition, then the hazards have to blink again, when not, put on ignition. Pull out the key, open and close driver's door, and test the remote.
    You can add max 3 remotes to the car.
    That's how Fords learn a remote, the Transit is the same animal like the others.
    American models are different, in that case you have to program the remotes with the keys if they are smart or half-smart or keyless go versions (Fusion Titanium or Flex or anything else) or you have to program 'em manually like Mustangs with remotes in the key head.
  6. #20
    lion0304's Avatar
    Oct 2014
    Procedure:
    4 times OFF - ON - OFF quick as you can do, remove key and press remote. That is correct procedure.
    It can be 8 times, but until now, all Ford i've did is 4 times
  7. #21
    Jan 2016
    Not on a mk7 transit though!
  8. #22
    rob h's Avatar
    May 2011
    The remote will work instant after programming a blue remotekey. (on a mk7)
    So these remote teachings procedures apply to cars with seperate remote.
  9. #23
    Dec 2016
    Have you tried it?!
    I add remote for ford focus MK2.
    Car locksmith
  10. #24
    jodge's Avatar
    Mar 2017
    cmon is not that hard
    Simple ford key separeted remote and immo chip. You can add via manual method
    Ford transit mk7 Blue key. The remote and the immochip is one unit. Both programed in the same time via diagnostic.
  11. The Following 2 Users Say Thank You to jodge For This Useful Post:
    canakbas (28th May, 2018), urcarpc (5th October, 2018)
  12. #25
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Blue reusable?
  13. #26
    newone's Avatar
    Oct 2016
    Quote Originally Posted by drugowaz View Post
    Blue reusable?
    as said in previous post yes
  14. The Following User Says Thank You to newone For This Useful Post:
    drugowaz (28th May, 2018)
