Results 1 to 5 of 5
    Jan 2018
    Orlando FL
    Default kia sportage 95910 -D9000 crash removed code B16200 cant be cleared
    Hi all,
    need help with 95910- D9000 , crash has been removed . code B16200 cant be cleared.
    Last edited by alejillo1970; 14th August, 2018 at 07:41 PM. Reason: not file attached
    slick_dick's Avatar
    Essex
    what is the description for that code!?
    “There's nothing more dangerous than someone who wants to make the world a better place.” ― Banksy
    Jul 2014
    Quote Originally Posted by alejillo1970 View Post
    Hi all,
    ok m8, now for remove code B16200 is easy, you only need to help someone here and after that you will be able to remove that....... understood
    Cheers
    slick_dick's Avatar
    Essex
    well said!
    i just wanted to see if it was a good file
    Jan 2018
    Orlando FL
    fair enough,
    unfortunately my knowledge is quite limited as you can appreciate from the time I have been member of the forum,
    however more than happy to help when the opportunity arises.
