Page 1 of 4 1234 LastLast
Results 1 to 15 of 60
    Administrator
    Devilfish's Avatar
    Feb 2008
    /cdk
    Default Editing the read-only parts of an image
    Enigma images are created in such a way that there is a read-only section of the image and read/write section. The /var folder and /tmp folder is the old folders in an image that you can edit. If, for any reason, you want to edit the read-only folders, i.e. /bin, /etc, /lib, /share, etc. this is what you'll need to do.
    First of all, you'll need a linux platform to make your changes. This could be a PC with a linux OS, i.e. Ubuntu, or you could have a program called VMWare which is a virtual machine that allows you to run a different OS from within an existing OS. It's up to you which one you choose and I will not go into setting it up in this thread.
    Telnet to the dreambox...
    username: root
    password: dreambox
    Follow these commands...
     mkdir /var/tmp/root
     mount -t squashfs -o ro /dev/mtdblock/5 /var/tmp/root
     cd /var/tmp
     tar -cf root.tar root
    FTP the root.tar to your linux desktop and open a terminal.
    cd Desktop
     tar -xf root.tar
    Leave the terminal window open.
    Treat the root folder on the desktop as the box itself but don't add or change anything in /var because that is a different location.
    When you have finished go back to the terminal window and...
     ./mksquashfs root mtd5.img -be
    Then ftp the mtd5.img back to the box. You will need a copy of mksquashfs on the Desktop to be able to perform this command.
    Telnet back to the box and...
     cd /tmp && eraseall /dev/mtd/5 && cp mtd5.img /dev/mtd/5 && reboot
    Done.
    To check what mtd# ...
    more /proc/mtd
    ...but most squashfs are mtd5.
    Njoy!
    Aug 2008
    is there anyway to do this from a Pc running on windows
    Jul 2008
    No, but you can install a virtual linux machine, using e.g. vmware, and do it from there. It's fairly easy to set up, and there's plenty of guides on the interweb.
    May 2008
    can anyone please tell me if this method works? I have tested so many times but not working. I have done and follow devilfish's instruction. I am able to produce mtd5.img but when I flash back to the box, the box dont work at all. Can someone please advise me?
    May 2008
    will this method work for neutrino on the dbox as well?
    Jul 2008
    Quote Originally Posted by ronlkh View Post
    Yes of course it works - This is the exact method I used to make the moddified jade image I posted in here.
    May 2008
    must I umount the root and delete the root.tar before I flash the new mtd5.img?
    May 2008
    What I am running is vmware + ubuntu 8.04.
    First I telnet to the dm500 from ubuntu terminal
    then I make directory
    root@dm500 ~ #mkdir /var/tmp/root
    root@dm500 ~ #mount -t squashfs -o ro /dev/mtdblock/5 /var/tmp/root
    root@dm500 ~#cd /var/tmp
    root@dm500 /tmp #tar -cf root.tar root
    root@dm500 /tmp #
    then I open another terminal to ftp to dm500
    root@ubuntu8041:/home/user/Desktop# ftp 192.168.0.112
    Connected to 192.168.0.112.
    220 Welcome to the PLi dreambox FTP server
    Name (192.168.0.112:user): root
    331 Please specify the password.
    Password:
    230 Login successful.
    Remote system type is UNIX.
    Using binary mode to transfer files.
    ftp> cd /tmp
    250 Directory successfully changed.
    ftp> get root.tar
    ftp>bye
    root@ubuntu8041:/home/user/Desktop# tar -xf root.tar
    root@ubuntu8041:/home/user/Desktop# ./mksquashfs root mtd5.img
    I mksquashfs back the original root and a new mtd5.img is created.
    then I ftp back to dm500
    Password:
    ftp> cd /tmp
    ftp> put mtd5.img
    ftp>bye
    exit back to Desktop and telnet back to the box
    i change the directory to /tmp
    root@ubuntu8041:/home/user/Desktop# telnet 192.168.0.112
    Trying 192.168.0.112...
    Escape character is '^]'.
    PLi dm500 Jade 20080718 (based on 1.09)
    welcome on your dreambox! - Kernel 2.6.9 (13:08:41).
    dm500 login: root
    Password:
    BusyBox v1.01 (2008.07.11-10:44+0000) Built-in shell (ash)
    Enter 'help' for a list of built-in commands.
    root@dm500 ~ # cd /tmp && eraseall /dev/mtd/5 && cp mtd5.img /dev/mtd/5 && reboot
    after image flashed dm500 reboot but dm500 is dead
    I did not umount the root directory in the /var/tmp nor I have deleted the root.tar
    Have I done anything wrong?
    Administrator
    Devilfish's Avatar
    Feb 2008
    /cdk
    On a working image, do a 'more /proc/mtd' in telnet and see what it says.
    May 2008
    Hi Devilfish,
    What I got is :-
    root@dm500 ~ # more /proc/mtd
    dev: size erasesize name
    mtd0: 00600000 00020000 "DreamBOX cramfs+squashfs"
    mtd1: 001c0000 00020000 "DreamBOX jffs2"
    mtd2: 00040000 00020000 "DreamBOX OpenBIOS"
    mtd3: 007c0000 00020000 "DreamBOX (w/o bootloader)"
    mtd4: 00800000 00020000 "DreamBOX (w/ bootloader)"
    mtd5: 004e0000 00020000 "DreamBOX SquashedFS"
    mtd6: 00120000 00020000 "DreamBOX Cramfs"
    Administrator
    Devilfish's Avatar
    Feb 2008
    /cdk
    That looks right, was just checking that the squashfs part was indeed mtd5. Not sure what else to suggest. Maybe try a totally different image.
    Sep 2008
    Hello there! I've just found this forum and have to say that i'm impress with it
    Continuing with the thread, I'm having the same problem as ronlkh here. I followed the steps explained by Devilfish except from the part of using a mksquashfs binnary copied on the Desktop. I used the mksquashfs binnary from ubuntu instead. Then, after rebooting, the dreambox does not respond and i get a black screen...
    I've read that squashfs-lzm is used for building most of the dreambox images, shouldn't will be using that program? Thanks in advance!
  13. #13
    Jan 2009
    hi,
    this is gr8 topic tested with gemini4.6 not work (Black screen after reboot)
    I do exactly same steps said Devilfish
    BR
  14. #14
    Administrator
    Devilfish's Avatar
    Feb 2008
    /cdk
    I followed these steps about a month ago to edit /var_init on an image so that certain files stayed there after a factory reset and it worked 100%.
    Maybe the SquashedFS partition is not mtd5 on a Gemini image, I'm not sure, but I imagine it would be the same.
  15. #15
    Jan 2009
    hi I get this
    root@dreambox:~> more /proc/mtd
    mtd0: 00500000 00020000 "DreamBOX cramfs+squashfs"
    mtd1: 002c0000 00020000 "DreamBOX jffs2"
    mtd5: 003e0000 00020000 "DreamBOX SquashedFS"
    I tried only to change a font in /share !!!
