Page 71 of 88 FirstFirst ... 2161666768697071727374757681 ... LastLast
Results 1,051 to 1,065 of 1306
  1. #1051
    winaiservice's Avatar
    Oct 2015
    Yes I do it but Scripts s Same UPA Clone
  2. #1052
    jjservice's Avatar
    Sep 2016
    VIENA,AUSTRIA
    IS THERE SOMEONE HAS A SCIPT FOR FORD ESCAPE DASH MC68HC11KA4 MCU?
  3. #1053
    hramos9's Avatar
    Aug 2016
    Hi mates, any script to read and change km on bsi 207 2012 compact ???? It's urgent eeprom 95160
    HONDA is fitted with a VTEC engine. When VTEC kicks in yo it causes the vehicle to accelerate insanely quick. Please be prepared for whiplash and similar injuries.
  4. #1054
    richiebb's Avatar
    Aug 2015
    Argentina
    Hi Folks.
    I'm learning how to make pascal scripts for upa.
    What I want is to order them in the list.
    I have seen some scripts that have groups and sub groups ........ eg dashboards -> peugeot -> 208 xxxxxxxxxxxxx ............. dashboard -> fiat -> stylo xxxxxxxxxx , etc.
    I also saw that there are .xscr extension files where this is generated, but the content is not plain text.
    If someone guides me a little I will thank him
  5. #1055
    Kocta's Avatar
    Mar 2017
    Garage in the Czech Republic
    Hey, does anyone script for Peugeot 307- Bsi Valeo. 2003-2004.
    Thank you
  6. #1056
    DK Veteran glk96000's Avatar
    Jul 2009
    Free
    anyone have read new renault airbag modul with xc2336b-40f
    need lift pin ?
    BR GLK96000
  7. #1057
    Jan 2010
    Trstenik - Thun
    i downloaded few scripts from here and when i try to execute any command from scripts i get error " argument out of range"
    are that scripts not compatible with my device or something else is problem?
  8. #1058
    Oct 2013
    hello i need to know how the scripts work ?
  9. #1059
    Jan 2010
    Trstenik - Thun
    Default UPA USB sample script wanted
    Quote Originally Posted by mikroel View Post
    Solved .Some scripts only work with cracked version of software but not with ori.
  10. #1060
    Feb 2011
    I have problem with script in UPA version 1.3 function perfect, but version upa-s no function
    Program Prog1;
    var
    Code,Code_1: string;
    KM: Integer;
    Procedure ReadKM;
    begin
    if not ReadDevice then
    begin
    MsgBox( 'Read Error', 'Error', MB_OK );
    end
    else
    begin
    AddMsg('VW Voyage 2009 9s12h256');
    Code_1:=inttohex(GetByteHexEdit($600),2)+inttohex( GetByteHexEdit($601),2)+inttohex(GetByteHexEdit($6 02),2)+inttohex(GetByteHexEdit($603),2);
    KM:= (strtoint('$'+Code_1)/1000);
    //KM:= ($ffff-strtoint('$'+Code_1));
    AddMsg('Actual value' + ' = '+ IntToStr(KM)+' km');
    MsgBox(IntToStr(KM) +' km', 'Actual value', MB_OK);
    end;
    end;
    procedure NewKM;
    var
    n,new_KM, new_KM2: integer;
    n1,n2: String;
    begin
    SetProgramModifiedOnly( true );
    if InBox( 'Enter KM', 'New KM', code ) then begin
    end;
    if StrToInt( code )> 999999 then begin
    MsgBox( 'Enter 000001-999999 Code', 'Error', MB_OK );
    exit;
    end;
    n:= StrToInt( code )*1000;
    new_KM2:= $FFFFFFFF-(n);
    new_KM:= (n);
    n1:= IntToHex(new_KM,8);
    n2:= IntToHex(new_KM2,4);
    SetByteHexEdit( $600,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $601,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $602,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $603,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $608,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $609,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $60A,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $60B,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $610,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $611,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $612,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $613,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $618,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $619,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $61A,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $61B,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $620,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $621,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $622,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $623,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $628,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $629,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $62A,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $62B,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $630,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $631,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $632,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $633,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $638,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $639,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $63A,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $63B,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $640,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $641,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $642,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $643,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $648,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $649,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $64A,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $64B,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $650,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $651,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $652,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $653,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $658,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $659,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $65A,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $65B,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $660,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $661,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $662,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $663,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $668,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $669,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $66A,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $66B,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $670,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $671,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $672,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $673,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $678,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $679,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $67A,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $67B,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $680,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $681,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $682,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $683,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $688,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $689,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $68A,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $68B,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $690,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $691,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $692,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $693,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $698,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $699,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $69A,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $69B,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $6A0,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $6A1,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $6A2,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $6A3,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $6A8,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $6A9,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $6AA,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $6AB,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $6B0,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $6B1,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $6B2,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $6B3,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $6B8,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $6B9,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $6BA,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $6BB,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $6C0,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $6C1,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $6C2,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $6C3,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $6C8,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $6C9,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $6CA,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $6CB,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $6D0,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $6D1,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $6D2,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $6D3,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $6D8,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $6D9,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $6DA,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $6DB,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $6E0,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $6E1,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $6E2,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $6E3,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $6E8,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $6E9,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $6EA,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $6EB,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $6F0,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $6F1,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $6F2,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $6F3,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $6F8,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $6F9,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $6FA,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $6FB,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $700,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $701,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $702,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $703,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $708,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $709,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $70A,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $70B,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $710,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $711,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $712,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $713,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $718,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $719,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $71A,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $71B,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $720,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $721,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $722,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $723,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $728,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $729,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $72A,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $72B,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $730,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $731,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $732,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $733,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $738,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $739,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $73A,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $73B,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $740,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $741,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $742,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $743,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $748,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $749,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $74A,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $74B,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $750,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $751,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $752,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $753,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $758,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $759,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $75A,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $75B,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $760,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $761,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $762,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $763,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $768,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $769,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $76A,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $76B,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $770,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $771,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $772,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $773,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $778,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $779,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $77A,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $77B,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $780,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $781,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $782,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $783,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $788,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $789,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $78A,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $78B,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $790,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $791,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $792,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $793,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $798,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $799,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $79A,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $79B,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $7A0,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $7A1,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $7A2,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $7A3,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $7A8,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $7A9,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $7AA,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $7AB,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $7B0,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $7B1,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $7B2,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $7B3,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $7B8,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $7B9,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $7BA,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $7BB,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $7C0,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $7C1,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $7C2,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $7C3,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $7C8,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $7C9,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $7CA,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $7CB,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $7D0,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $7D1,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $7D2,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $7D3,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $7D8,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $7D9,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $7DA,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $7DB,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $7E0,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $7E1,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $7E2,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $7E3,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $7E8,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $7E9,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $7EA,(strtoint ('$'+n1[5]+n1[6])));
    SetByteHexEdit( $7EB,(strtoint ('$'+n1[7]+n1[8])));
    SetByteHexEdit( $604,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $605,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $606,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $607,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $60C,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $60D,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $60E,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $60F,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $614,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $615,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $616,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $617,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $61C,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $61D,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $61E,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $61F,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $624,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $625,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $626,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $627,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $62C,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $62D,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $62E,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $62F,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $634,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $635,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $636,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $637,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $63C,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $63D,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $63E,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $63F,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $644,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $645,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $646,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $647,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $64C,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $64D,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $64E,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $64F,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $654,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $655,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $656,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $657,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $65C,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $65D,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $65E,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $65F,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $664,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $665,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $666,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $667,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $66C,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $66D,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $66E,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $66F,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $674,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $675,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $676,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $677,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $67C,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $67D,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $67E,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $67F,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $684,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $685,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $686,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $687,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $68C,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $68D,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $68E,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $68F,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $694,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $695,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $696,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $697,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $69C,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $69D,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $69E,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $69F,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $6A4,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $6A5,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $6A6,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $6A7,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $6AC,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $6AD,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $6AE,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $6AF,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $6B4,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $6B5,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $6B6,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $6B7,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $6BC,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $6BD,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $6BE,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $6BF,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $6C4,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $6C5,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $6C6,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $6C7,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $6CC,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $6CD,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $6CE,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $6CF,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $6D4,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $6D5,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $6D6,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $6D7,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $6DC,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $6DD,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $6DE,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $6DF,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $6E4,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $6E5,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $6E6,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $6E7,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $6EC,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $6ED,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $6EE,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $6EF,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $6F4,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $6F5,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $6F6,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $6F7,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $6FC,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $6FD,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $6FE,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $6FF,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $704,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $705,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $706,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $707,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $70C,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $70D,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $70E,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $70F,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $714,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $715,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $716,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $717,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $71C,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $71D,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $71E,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $71F,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $724,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $725,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $726,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $727,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $72C,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $72D,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $72E,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $72F,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $734,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $735,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $736,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $737,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $73C,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $73D,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $73E,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $73F,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $744,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $745,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $746,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $747,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $74C,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $74D,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $74E,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $74F,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $754,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $755,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $756,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $757,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $75C,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $75D,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $75E,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $75F,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $764,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $765,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $766,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $767,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $76C,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $76D,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $76E,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $76F,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $774,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $775,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $776,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $777,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $77C,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $77D,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $77E,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $77F,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $784,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $785,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $786,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $787,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $78C,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $78D,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $78E,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $78F,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $794,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $795,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $796,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $797,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $79C,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $79D,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $79E,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $79F,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $7A4,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $7A5,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $7A6,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $7A7,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $7AC,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $7AD,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $7AE,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $7AF,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $7B4,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $7B5,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $7B6,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $7B7,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $7BC,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $7BD,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $7BE,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $7BF,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $7C4,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $7C5,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $7C6,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $7C7,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $7CC,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $7CD,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $7CE,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $7CF,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $7D4,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $7D5,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $7D6,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $7D7,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $7DC,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $7DD,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $7DE,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $7DF,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $7E4,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $7E5,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $7E6,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $7E7,(strtoint ('$'+n2[7]+n2[8])));
    SetByteHexEdit( $7EC,(strtoint ('$'+n2[1]+n2[2])));
    SetByteHexEdit( $7ED,(strtoint ('$'+n2[3]+n2[4])));
    SetByteHexEdit( $7EE,(strtoint ('$'+n2[5]+n2[6])));
    SetByteHexEdit( $7EF,(strtoint ('$'+n2[7]+n2[8])));
    RefreshHexEdit;
    if MsgBox( 'Program?', 'Confirm', MB_YESNO ) = IDYES then begin
    ProgramDevice;
    VerifyDevice;
    ReadKM;
    end;
    end;
    begin
    AddDeviceGroup( 'VW', 'Select a car' );
    AddDevice('VW Voyage 2009 9s12h256', 'MC9S12H56', 'VW', 'MC9S12H256' );
    AddAction( 'Read KM', 'ReadKM', 'VW Voyage 2009 9s12h256' );
    AddAction( 'New KM', 'NewKM', 'VW Voyage 2009 9s12h256' );
    AddOpenFileAction( 'Connection', 'VW Voyage 2009 9s12h256', 'voyage.jpg' );
  11. The Following User Says Thank You to autotechbr For This Useful Post:
    Taeza04 (22nd July, 2017)
  12. #1061
    Dec 2010
    vietnam
    HI M8! PLS help me! how to convert HEX to DEC script?
    procedure Button2Click(Sender: TObject);
    var code,CODE_1: string;
    KM: Integer;
    begin
    code := inttohex(GetByteHexEdit($08),2)+inttohex(GetByteHe xEdit($09),2)+inttohex(GetByteHexEdit($0a),2)+intt ohex(GetByteHexEdit($0b),2);
    KM:=strtoint('$'+Code);
    Edit1.text := IntToHex(KM,9);
    end;
    end;
  13. #1062
    MSolen's Avatar
    Dec 2009
    universe
    I'm looking for scripts for UPA-USB for the Suzuki Kingquad LTM700 dash km and moto hours on 24LC02 memory
  14. #1063
    Sep 2014
    Anybody have script for Mazda CX5 2012 ?
  15. #1064
    Jul 2017
    Amigão, eu preciso calcular o km da eprom 93C46 do celta. como calcular na upa? la so aparece 93S46. qual a linha que fica armazenhada o km e como calcular?
  16. The Following User Says Thank You to noronha For This Useful Post:
  17. #1065
    Dec 2015
    manaus amazonas
    where can i find this software for upa script encryption
