Make sure you are doing it exactly as the tut says
NOTE: All of the following is case sensitive. Make sure you take note of the case!
Type in the following and hit the enter key on your keyboard:
dl 800000 (the l is a lowercase L)
You should now get the following message returned in the command window.
S record load, offset: 800000
You will not get the command prompt back at this point; it will just be stating that message above. At this point you need to click on “Transfer” from the menus at the top of the hyper terminal. In the drop down list click on “Send Text File”
You will now get a browse window to find a file. Change the ‘Type of file’ to be “All Files” from the drop down list at the bottom. You now need to navigate to the place you extracted this guide to as it also come with the files you need. So when you have navigated to the correct place, click on U-BOOT.MOT then click on open. It will now start to transfer. This will take about 5 minuets and will not show any information about it on the HyperTerminal. After about 5 minuets when it has completed, you will get the following message on the HyperTerminal and be returned to the command prompt.
DL: start ADDRESS 0x800000
Try this uboot file
