bosch have the same adapter but you must have kts diag
this adapter if for KTS
Yes.in the ECU of the pump is MCU and errors are stored in it.You can test it with simple K-Line interface and dennis sofftware it is free.If you have a KTS and plug from old car electrical system you need female connector to build a tester.
Opcom works very well with VP44
i find this vp tool with software ,
work to live
See k-line -for testing with software from dennis .You need power ,ground and k-line.But i thing works with com port not usb/com.Soft is in post 590 in here.
Well i jast recive some staff
1 KKL china clone vag/usb clone
and some vpp electronic block
for 5 min with 12 V adapter and a couple of cables made this thing.
on the pic 2
1 line riginal core of the pump.
2 line:?
3 line:?
4 line :?
5 line :bosh Number
Michael28 (18th October, 2019)
This is with russion lang.
I made a test with opcom rev 109 ,but there is no answer from ECU.I am nor shure that my opcom is OK.I will test it tomarrow.
Sorry for posting two posts one after another,but I can not put pictures in edit mode.
for people considering buying bosch kts i seem to remember hearing the latest updates have removed direct pump functions...virgin etc. advise check with supplier before purchase and request confirmation in writing so if function is removed you could claim money back saying not fit for purpose of which you purchased, ie. pump functions, regards steve
