Page 1 of 5 12345 LastLast
Results 1 to 15 of 63
    Jan 2011
    Default PEUGEOT 206 EDC16C3 defective - IMMO OFF on new ECU?
    Dear mates,
    I meet a serious problem on a P206 1.4 HDI vehicle with EDC16C3 ECU: on the athmospheric pressure reading hole the water enters in the ECU and destroy the ECU (I cleaning the board, but I can't read the ECU via BDM, allways display communication error or power supply drop), I dismantle completly the ECU and found a lot of dirty on the SPI eeprom (95160). I desoldered the eeprom and the memory dump is fully 0! So, I can't clone the defective ECU...
    The customer have another ECU, but I don't know what is the best solution to resolve the car.
    If enough to remove the IMMO from the ECU dump, please remove it, if not enough please describe the procedure. I have acces only for DEC diadnostic equipment (is veri good in BSI coding for Peugeot, but I can't acces "original" PSA diagnostics).
    Thanks in advance!
    Best regards,
    Feri
  2. The Following User Says Thank You to uferi For This Useful Post:
    MARIKO (7th January, 2020)
  3. #2
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    Jul 2009
    In my immobox...
    Your file off:
    4C7570755F73616E64755F696D6D6F5F736F6C7574696F6E73
  4. The Following User Says Thank You to lupu_sandu For This Useful Post:
    maher1800 (18th January, 2020)
  5. #3
    Jan 2011
    Hi Sandu,
    thanks a lot, tomorow I will test on the car and report the result!
    Best regards,
    Feri
  6. #4
    Sep 2009
    hi, i have similar probleme with ecu 206 1.4 hdi edc16c3 0281010707
    this is my original dump
    please can someone help me with off
  7. #5
    lupu_sandu's Avatar
    Jul 2009
    In my immobox...
    Quote Originally Posted by ricards99 View Post
    Your dump off:
  8. The Following User Says Thank You to lupu_sandu For This Useful Post:
    MAYQUAD (28th June, 2014)
  9. #6
    Jan 2011
    Default P206
    Quote Originally Posted by lupu_sandu View Post
    Your file off:
    Dear Sandu,
    the car now is working, thanks a lot for your help!
    Best regards,
    Feri
  10. #7
    Nov 2009
    Morocco
    hi lupu,
    can you please help me with off for 307 1,4 hdi EDC16C3 47
    0281 010 390 here is my ori
    thanks in advance
    Please don't be discouraged, Nothing comes easy in life
  11. #8
    Dec 2010
    The best way is to desolder / remove flash 29BL802CB and 95160 from destroyed ECU and solder it to new ECU.
    Plug and play!
    Did this several times. 100% working, of course ECU must be same (bosch numbers)
  12. #9
    joubliss's Avatar
    Jan 2010
    Far away
    Quote Originally Posted by hamza338 View Post
    hi lupu,
    thanks in advance
    Take this, its ur dump with immo off.
    Job
  13. #10
    Mar 2010
    spain
    Red face
    hi lupu,
    thanks in advance
    i have the same problem
  14. #11
    rabbitepp's Avatar
    Feb 2011
    your off file
    pass pm but you must delete some message from your inbox
  15. The Following User Says Thank You to rabbitepp For This Useful Post:
    lichir (11th August, 2019)
  16. #12
    Nov 2009
    Morocco
    Quote Originally Posted by joubliss View Post
    Job
    thanks meat, but degraded mode 3000/min. still looking for help thanks.
  17. #13
    DAHDOC's Avatar
    Jan 2010
    UK WEST YORKSHIRE
    Default 206 immo off needed
    Here i have a 206 ecu i need immo off please
  18. The Following User Says Thank You to DAHDOC For This Useful Post:
    manel19 (29th October, 2020)
  19. #14
    DK Veteran jruibarroso's Avatar
    Dark Side of the Moon
    Default 206 EDC16C3
    Hi , can you immo-off my dump please ?
    thank you
    All of my posts are for educational purposes only.
    If this was helpful to you, please press THANKS
  20. The Following User Says Thank You to jruibarroso For This Useful Post:
  21. #15
    Dec 2010
    Default 206 EDC16C3
    Quote Originally Posted by jruibarroso View Post
    thank you
    there you go
  22. The Following 3 Users Say Thank You to latino For This Useful Post:
    manel19 (29th October, 2020), MARIKO (7th January, 2020), zorans (26th August, 2019)
