Page 10 of 16 FirstFirst ... 56789101112131415 ... LastLast
Results 136 to 150 of 240
  1. #136
    p1et's Avatar
    Oct 2013
    I found calculator on website also. We'll see which one is correct. First person here who helped with codes always put X for Mini. Will report tomorrow,
  2. #137
    drugowaz's Avatar
    Mar 2015
    Lithuania
    where to input this code. by obd? what tool?
    Renault ECU tool / IO terminal / A.S.W
  3. #138
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by drugowaz View Post
    AD100 pro / MVP
  4. #139
    tmkz's Avatar
    Sep 2010
    PL
    hi need barcode, serial number on pcb 236393 LR DISCO 2
  5. #140
    coolsoda's Avatar
    Apr 2008
    Scotland
  6. #141
    Aug 2013
    Spain
    In Spain mini have the N letter like rover.
  7. #142
    Nov 2015
    UK
    sorry my bad
  8. #143
    Nov 2015
    UK
    Quote Originally Posted by P&D View Post
    BMW start with X not G
    G = Land rover
    X =BMW
    N =Rover
    *X406B4C406B4BFF7* *FFFFFFFFBF94B31*
    Just need some clarification please.
    Here I read all posts.
    On Brads post I see G as Europe country code.
    Above I see G as Land Rover.
    Please can you just advise.
    Thanks very much.
  9. #144
    Jun 2010
    Europe
    It actually doesn't matter, you don't have to enter that part of the barcode.
    If you do have to enter it, it still doesn't matter since the ECU doesn't save it. Maybe your diagnostic equipment will warn you about the wrong type of remote or something like that (if so just try a different letter), but the car doesn't store it.
  10. The Following User Says Thank You to tomvleeuwen For This Useful Post:
    Faraday (10th January, 2022)
  11. #145
    vsanyi's Avatar
    Aug 2012
    Mini cooper works with keydiy remote?
  12. #146
    Nov 2015
    UK
    If you mean as kemaster say's......see photo
    Extra yellow box mean's land rover remote
    without yellow box only rover 75 & Mini
    Can you advise what that extra yellow box is for / what it does on the Land Rover.
  13. #147
    Nov 2015
    UK
    Quote Originally Posted by tomvleeuwen View Post
    The letter needs to be used for the target vehicle so you need to use the correct letter with the code to obtain the correct long code number.
    Having said that my questions was that i see 2 explanations for the one letter.
    I read G was for Europe but i then see that G = Land Rover.
    Reading all these posts again i now believe that the letters G X N refer to Vehicle and not country code
  14. #148
    Feb 2018
    Glasgow area
    Quote Originally Posted by vsanyi View Post
    Yes. B Type remote offers pincode or standard BMW EWS Remote.
  15. The Following 2 Users Say Thank You to PixelsFixed For This Useful Post:
    Faraday (10th January, 2022), vsanyi (13th October, 2018)
  16. #149
    vsanyi's Avatar
    Aug 2012
    Quote Originally Posted by Buddy41 View Post
    You tried? I can remote synchronization with Launch? Pincode type.
  17. #150
    vsanyi's Avatar
    Aug 2012
    Sory!The question is PixelsFixed.
