Page 2 of 2 FirstFirst 12
Results 16 to 29 of 29
  1. #16
    Sep 2009
    GB
    Remove this capacitor (or change 470pf) and change 10nf ok.Work and read write transponder
  2. The Following 2 Users Say Thank You to hbalazs For This Useful Post:
    Ginocar (26th October, 2013), HeXeN (21st June, 2015)
  3. #17
    whiskeyman's Avatar
    Dec 2010
    where men are men and women eat their babies
    hi lads i have carprog original but have clone antenna and seems crap
    anyone tried making one from say fiat immo ring
  4. #18
    Sep 2016
    PLZ CAN CKARIFY BETTER I DONT UNDERSTAND
    I TOLD MY CLONE CARPROG ATTACHED THE ANTENNA OR NOT ATTACHED SAME MESSAGE NO ANTENNA ATTACHED
    WHERE WILL BE THE PROBLEM
    THANKS
  5. #19
    jakesman's Avatar
    Oct 2013
    Bethlehem Southafrica
    Antena.rar
    i just removed like in picture and replaced the resistor only i did not do the caps and it is working fine for me
  6. #20
    electronistul21's Avatar
    Nov 2011
    galati,romania
    carprog antena work only in 4.74 and 8.21 version and never to another version.can use original antena from carprog kit,ist very good.
    solution:
    1. replaced 150k with 15k (resistor)
    2+3+4 here we need to solder a capacitor with aproximately 6-7 nF(put one or combine from 2-3 capacitors)
    5. removed 100 nF capacitor
    6. removed 100 pF capacitor
    in position 2 it was a 2.8nF capacitor
    in pos 3 it was 0.5 nF cap
    in pos 4 it was 100 nF cap
    good luck!
    Carprog 8.21,xprog 5.55,galletto v54,kess and ktag rework
  7. #21
    jakesman's Avatar
    Oct 2013
    Quote Originally Posted by electronistul21 View Post
    solution:
    good luck!
    mine was 7.xx bur real version was 4.01 and antenna did not work i just removed the caps and did not fit any other caps just swaped out the resistor and woopy now antenna is working , first test was with toyota key and second test was with benz sprinter all good
  8. #22
    Nov 2011
    galati,romania
    try in id 48can vw.you can read CS?
  9. #23
    Aug 2015
    Hello there,
    My antena is from an golf IV with resitance 23ohm
    Here are the mods i did:
    PICTURE: [url=http://kepfeltoltes.hu/view/161019/transponder_IC__www.kepfeltoltes.hu_.jpg]
  10. #24
    Aug 2012
    Hi guis i am new in the world of Dk and want to tell hi to all from Bulgaria, a want to know if someone test the solution posted from WIPPO69 it works or not,i have the carprog 8,21 clone and make me the same error when want to read some key? thanks in advance to all
  11. #25
    jakesman's Avatar
    Oct 2013
    the only and only reason i got carprog is for opel ecu pin read , the other stuff is just aded bonus but on vag id 48 can i did
    not try that , for vag i use other tools but good question i will try and see thanx m8
  12. #26
    Nov 2011
    galati,romania
    you can use carprog for read and write CS to transponder ID48, preparing key for adding to car.
  13. #27
    Dec 2016
    Hello,
    I have another problem. The error message is "Transponder signal to low". Does anybody know where is the problem please?
    thank you
    Ladislav
  14. #28
    Apr 2018
    This solution works for me. I tested on 48 with Audi A4 B5 99r. I am sending a photo as I solved it on my Carprog. My antena have 3ohm.
    The only problem I see is that the antenna has a problem with catching the transponder. You have to make many attempts before setting the position of the key in the right way. Another time, the message pops up like in Ladis1510.
    I will try to make antena from the Audi ori solution (from car).
    I will share if it works better than the clone Carprog antena.
  15. The Following 2 Users Say Thank You to kamaz007 For This Useful Post:
    Qpcomma1 (4th August, 2020), xuniter (23rd November, 2021)
  16. #29
    Feb 2020
    Polska
    If anyone has a problem with the antenna, there is a detailed description with a photo of how to solve it.
