launch easydiag m.diag Does golo have offline and offline wants email xxxxxxxxxxxxxxxxx
I have problems with Honda’s SRS systems , on newer 2013+ Honda’s when trying to recalibrate OPS seat sensor launch says “no communication to ECU or vehicle not equipped” and on older 2011 or older it says “calibration ok” but srs light still on and ops failure code.
in past 2 weeks I had about 5 Honda’s that this happened.
Another guy with autel MaxiSYS pro ms908p came and fixed these hondas in few seconds
recently updated to x431 pro3, and its very unstable.
Using it on Samsung galaxy s6 with yellow easydiag connector
Hi.
I have x431 5c. It tells me that empty memory can not be updated. Is there any way to make it work with the SD card that is not busy?
hi i have a x431 (x-diag pro3 ),on a tablet, updates have stopped and it says "no network found " which is not so, version v3.11.029
s/n 969190006845
hello to all. recently I became the owner of un "launch x431 quicheck".the problem is that the card was formatted amd the software is lost.I tried to register the product on x431.com for downloading the software.butit was impossible.Maybe the tool is too old (2012).For this reason I ask to you if somebody can help me with the software for this tool. the serial no. is 981290077800 VO, registration no. 981270077300 (from envelope),and dealer code is 343002A (launchiberica).Please,i need you help
xdiagpro global (16th December, 2019)
I bought a used easydiag 3 yellow ,previous owner used cracked firmware ,i want to restore it and use it as original on ipad , can someone provide me ori boot files to restore it?
insert an external SD card on tablet to make it work.5C memory is very little space couldn't load so much software volume.
good news.i recovered the card.now it is working.but it has only demo and obd2.i need un update.can somebody to help me?
this is very old machine,launch stopped the new software update...very bad news
Change the screen I had the same problem.
