Results 1 to 4 of 4
Threaded View
    DK Veteran manocao's Avatar
    Sep 2009
    Default Repair vag-com 409.1 kkl interface with ft232rl and lm339
    if ftdi ic is recognized by windows, that is, if you can install drivers, but the interface doesnt work (test in vag-com 3.11 or 409.1 or vcds-lite) then lm339 smd ic is broken
    this is a common problem, lm339 burns very often...
    you can buy in local dealer (0.30euro) or ebay (10x 1.80usd)
    remove it with the help of two soldering irons: solder all pins together in both rows of 7 pins and then heat both rows, the ic will easily separate
    then solder the new ic: position the ic, solder 4 pins in the corners so that it doesnt move, and then the full ic
    im waiting for new lm339 to arrive and then will try
    edit 16th april 2013:
    today i received the 10x lm339, i soldered one and interface is working perfect, only some cents to repair
    with the flux it is very easy to solder this ic
    this confirms that lm339 is the problem, which usually burns out, it's just as easy as replace it
    __________________
    China: OPEL Tech2 non-CAN multiplexer USB, OP-COM USB, OBDII Elm327 USB, VAG-COM 409.1/VCDS Lite 1.0 KKL USB
    Homemade: UNISCAN Visa 1.83 RS-232, Renault XR25PC USB, BMW KKL USB, Nissan Consult1 USB
  2. The Following 2 Users Say Thank You to manocao For This Useful Post:
    mexanico1971 (2nd August, 2013), titoun (19th September, 2016)
