hi.
i need das or xentry SPECIAL OR OFFLINE key for w204.
WDD6F41W38A149702
THANKS.
HI.PremierD.
CODE not work, excuse-me , i put chassis with error, the wrong chassis.!!!!!
this chassis is correct ( WDDGF41W38A149702 )
CODE DAS or XENTRY?????
THANK YOU.
giovani (27th November, 2013)
I have tried this software calculator so many times, As far as I am concerned it does not work on anything...... plus some of the menus are not accurate descriptions of the process.
I tried it with 11.11 12/05 13.03 and it is not worth testing on 09.2013 - maybe I should spend more time translating development Data, there is a lot more in there we do not use or understand...
If anyone has had any success with this calculator please give details, and if u can take a pictureof it working showing versions, date as, etc/
...even better
Hello impactops, I have replaced a wsp module but am unable to generate the key FDOK to lernthe transponder. Can You Help With This?
CHASIS: WD2YD241025355812
RANDOM NUMBER: 7C F4
ID CODE (SERIAL NUMBER OF CONTROL MODULE WSP): BA 12 D0 46
CALCULATION TYPE: X1
NUMBER OF KEYS: 1
TRANSPONDER CODE: 8B 8B A5 68 FB
Thanks for any help and advice you can give me. The way DAS is set up I thought I was able to generate it myself through the learning keys but it was not in the menu.
Thanks Again!
Keygen for 22 special functions available for free. PM for link.
Best regards
McTallman
ACDC (6th October, 2014), ahadi (5th May, 2014), andrius (5th October, 2014), bugajewski_pl (4th March, 2014), DB_member (25th February, 2014), eliasole (24th February, 2014), maddy7 (24th February, 2014), MBFIX (6th March, 2014), MishaNew (9th January, 2024), mrouzo (13th April, 2015), nhojyelbom (5th May, 2015), niko75 (19th May, 2014), Novik_UA (8th May, 2014), Pali33 (8th May, 2014), pao (12th September, 2016), said72 (14th April, 2014), schwobaschlamber (13th May, 2014), SergeyIg (11th March, 2014), sherl645 (12th December, 2015), taxo1965 (11th October, 2017), wuerfel (21st November, 2016)
anyone have a password gen for 09/2015 xentry?
Thank you, its good to have it.
I can help with translating guys, I'm a fluent German speaker
